Grinding/rattling while decelerating or coasting at highway speed
Discussion in 'Trucks [ Eighteen Wheelers ]' started by PJM41, May 4, 2021.
  1. PJM41
    PJM41 Bobtail Member
    20
    Oct 26, 2018
    Grinding/rattling while decelerating or coasting at highway speed.
    Below are the traits:
    -2015 Mack with automated trans
    -only happens when empty
    -occurs while coasting or decelerating at highway speed (mostly in 12th, less so in 11th gear on a 12 speed)
    -can feel grinding in my feet
    -will smoothen out once the truck begins to accelerate again
    -putting the truck in neutral causes it to stop
    -rattle often progresses to a grind when the truck is giving the slightest bit of throttle so that the engine starts to minimally build but not enough for the truck to start pulling/ accelerating again
    -sometimes when hitting throttle to accelerate, it will hesitate and grind for a split second before engaging and smoothing out
    - doesn’t happen every empty trip, but has been occurring more frequently by the week and now occurs 60+% of empty trips
    -rattle sounds almost like an older roller coaster being pulled up the initial hill by the rattling/clunking chain
    -grinding has a higher frequency similar to a vibrator plate
    -all of it sounds/feels like metal to metal
    I am thinking maybe flywheel, trans, driveshaft joints/yokes or rear differential?
    Any thoughts? I have a dealership appt this Wednesday but am hesitant to bring it in without a clear direction of where to look or a guarantee that they will be able to duplicate symptoms.
    Thank you,
    Pat
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Look at the air bags on rear drive axles if they are too hi or to low that's what's making it sound off ?
  4. lester
    2,956
    8,083
    Jan 2, 2012
    NW, Iowa
    Definitely check ride height. It can make some crazy sounds if it's off and in my experience it usually does it when coasting or steady speeds
  5. PJM41
    20
    Oct 26, 2018
    thanks guys. The leveling valve was replaced at the Mack dealer in late december and they specifically stated they spent a couple hours making sure the ride height and drive line angles were in spec, so I assume they are still good but will be double checking.
  6. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    could be bad differential , hopefully not the idler gear
