Grinding sound
Discussion in 'Volvo Forum' started by believe456, Jul 18, 2018.
  1. believe456
    believe456 Light Load Member
    191
    22
    Apr 22, 2015
    I have an 06 vnl670 Cummings motor Eaton fuller autoshift. When I’m really heavy the truck Makes a grinding sound I’m first gear or reverse when i first hit accelerator. Last about a half second. If i ease on accelerator it doesn’t do it. I changed out one of the drive shafts thinking it was that. No change. Any ideas???
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Check u-joints and carrier bearings also.
    Dave_in_AZ and magoo68 Thank this.
  4. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    Throwout bearing on clutch or pilot bearing on flywheel.
    Dave_in_AZ Thanks this.
  5. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    Do you lose air presure, is the compressor running nonstop while parked idling under heavy load? Could be the air springs leaking on drive axle, won't lift/ hold heavy load at leveling height in idling mode low rpm, changes the driveline angle. It happens to hear grinding noise when leveling valve/rod goes bad. Just an idea!
  6. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Might be that Cummings motor giving all the trouble, try replacing with a CUMMINS.
    Lol, I'm kidding.
    How many miles on the trans?
    Might be super sloppy..
    mslashbar Thanks this.
  7. believe456
    191
    22
    Apr 22, 2015
  8. Arkansas
    Arkansas Medium Load Member
    514
    669
    Dec 20, 2014
    LA- Lower Arkansas
    Check the leveling valve on your airbags
  9. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Most likely worn out bearing slop. At 1.6M it Doesn't owe anybody anything ....time for a freshening..
