Grinding when selector valve is switched up
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Codynidaho, Mar 3, 2020.
  1. Codynidaho
    Codynidaho Light Load Member
    87
    20
    Apr 8, 2016
    Cheyenne, Wyoming
    Hello,
    I'm not finding much about my issue. But from what I could find is that I may be to late and my synchros are bad. I'm getting grinding Everytime I move my selector switch from down to up. It doesn't do it going down. I ordered a rebuild kit for the air valve on the transmission but I have a feeling that's not the problem.
    I'm looking for some confirmation on worn out synchros. Help would be appreciated.
  3. Codynidaho
    87
    20
    Apr 8, 2016
    Cheyenne, Wyoming
    Also, I'm dealing with an Eaton 18speed.
  4. AModelCat
    164,941
    Most likely worn out synchro. The synchro is a wearable part. If its worn out, it won't get the gear speeds synchronized in time before the dog teeth try to mesh, so they grind a bit.
    Bean Jr. and HopperHauler Thank this.
  5. HopperHauler
    HopperHauler Trucker Forum STAFF Staff Member
    514
    1,684
    Jan 22, 2011
    North Dakota
    My 13 did the same thing, it was the synchronizer. I pulled the rear unit off and took it to a transmission shop, he had a new synchro kit put in in about an hour and a half.
    Bean Jr. Thanks this.
  6. AModelCat
    164,941
    Wouldn't be a bad time to re-seal the range and splitter pistons while you have the aux section out either. Could also consider a re-bearing of the aux countershafts and output shaft if they look questionable.
    HopperHauler Thanks this.
  7. bzinger
    bzinger Road Train Member
    16,659
    66,213
    Dec 10, 2014
    omaha , ne
    My Eaton 10 speed started doing that occasionally going from hi to lo and quit doing it on it's own.
  8. Codynidaho
    87
    20
    Apr 8, 2016
    Cheyenne, Wyoming
    Thanks for the input. I'll let the customer know. I'm a mobile service and I'm not about to tear into the trany in windy Wyoming. Lol
    Bean Jr. and bzinger Thank this.
