Gross weights
Discussion in 'Flatbed Trucking Forum' started by RollinThunderVet, May 15, 2019.
  1. RollinThunderVet
    RollinThunderVet Heavy Load Member
    717
    970
    Just want to make sure I have this right...
    Out here on the eastern side i can only load 44k to keep under 80k.
    I'm heading to Seattle now, and they allow up to 105k gross. So if i run a WA to WA load i can legally run at 87k? (13,200 + 34,000 + 40,000) since i can split my rear...?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Take a look at your cab card... how much does it say for weight beside WA?
    Otherwise if you are legal for bridge law and axle laws... go for it. Assuming WA isn't one of those states that requires intrastate authority.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Need a four axle truck and three or four axle trailer. For 105,000
    BUMBACLADWAR, x1Heavy and Cat sdp Thank this.
  5. RollinThunderVet
    717
    970
    Obviously... my question wasnt can I run 105k.
    It was in states that allow over 80k without permits, do I have to go by the cab card or just axle weight limits.....
  6. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Both...
    So in theory you could do 20k steer 34 drives and 20+20 on your spread, if your steer axle and tires were rated for it and somehow balance the weight like that..
    For interstate limits at least. If it's less for steer axle for state routes then 12-34-20/20=86k..
    MartinFromBC Thanks this.
  7. RollinThunderVet
    717
    970
    That's what I was hoping...
    I've got 13,200 front so I'm hoping I can be legal running up to 87,200. WA, ID, MT, all have a 105k max, so it'll be nice to be able to run a heavier load than what is allowed back home..
  8. Cat sdp
    Cat sdp . .
    21,312
    76,266
    Apr 8, 2012
    Orion's Belt
    Gotta believe you need overweight permits (annual) from each state ......
  9. Espressolane
    18,691
    117,160
    You need to see what your registered weights are.
    Take a look at cab card, it should list your max gross for each state.
    If your on 5 axles, even with a spread, bet it’s 80k.
    miszel Thanks this.
  10. RollinThunderVet
    717
    970
    Not according to each states DOT websites.
    Like WA, max legal gross is 105k, providing you are good on your axle weight limits then you dont need a permit until you hit 105,001 lbs.
    I'm going to be stopping and verifying with the scale houses on my way to Seattle.
    Cat sdp Thanks this.
  11. RollinThunderVet
    717
    970
    That's the only problem I see that could screw it up. I'm going to be redoing my cab weights when I renew my registration this year
