grounding question cobra 19
Discussion in 'CB Radio Forum' started by ericsm34, Jun 30, 2017.
  1. ericsm34
    ericsm34 Bobtail Member
    I have a cobra 29 in a 2013 Freightliner, I hook up the power wire and the radio turns on without the ground being hooked up, what would cause this, also after hooking up the ground wire, when I key the mic my fm radio cuts out.
  3. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    What ground are you talking about? RF ground or D.C. ground?
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Radio is getting ground threw the coax...Think I would check SWR...could be threw the roof.
  5. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    Grounded via coaxial cable. Not good. Needs a dc ground to radio itself.
  6. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    DC ground doesn't guarantee RF ground. You know that, Rabbi!
    rabbiporkchop Thanks this.
  7. rabbiporkchop
    9,678
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    you need both.
  8. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Technically not on a magnet antenna, granted we know he isn't running one.
  9. CW Spook
    CW Spook Light Load Member
    Stolen from the ARRL page on grounding...
    4. How do mobile HF operators get RF grounds? For obvious reasons, the 8-foot buried pole won't work.
    In a typical HF setup, the car is capacitively coupled to the ground, so the antenna is something sort of like a cross between a lopsided vertical dipole (with the whip being one side and the car the other) and a vertical with elevated radial system.
    With a magnet mount, you get capacitive coupling between the antenna and the surface on which it's mounted. In other mounting scenarios, it's still the same theory. That's why it's sometimes necessary to run an RF ground wire to the body of the vehicle.
