Guages
Discussion in 'Ask An Owner Operator' started by Ikamob01, Apr 22, 2022.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Looking at the pictures, which guage is for tractor and which one is for the trailer?
  3. GreenPete359
    GreenPete359 Road Train Member
    2,260
    5,441
    Oct 21, 2017
    Driving my recliner
    Both are for both. Top is primary air & bottom is secondary air.
    NYStarcar, Brettj3876 and D.Tibbitt Thank this.
  4. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Yeah, you have two separate gauges for primary and secondary Air. The gauge that has the “Twin needle” setup is your two gauges in one. Either setup is fine. If you do have a gauge that measures trailer brake pressure it will sit at zero and build pressure as you apply trolly pressure. No guarantee that it comes factory. Some have, some don’t.
    motocross25 Thanks this.
  5. Ikamob01
    314
    195
    Dec 4, 2021
    I don't get it. Elaborate.
  6. Mchestnut1
    Mchestnut1 Bobtail Member
    28
    23
    Apr 13, 2020
    USA Florida
    Both are for truck and trailer
    Not separated
  7. AModelCat
    164,992
    Neither gauge is for the trailer. One gauge is the truck's primary reservoir pressure and the other is the truck's secondary reservoir.
    The only gauge you might have for trailer air would be one for trailer brake application pressure and that's not a required gauge so not every truck has it.
    Brettj3876, GYPSY65, D.Tibbitt and 3 others Thank this.
  8. motocross25
    motocross25 Road Train Member
    3,890
    11,964
    Sep 23, 2010
    Overland Park, KS
    What @Largecar359 is saying is you have 2 gauges, Primary Tank (1) and Secondary Tank (2). On some trucks there is one gauge with 2 needles of different colors to differentiate the tanks, using the same pivot point. On a setup like that then the one in the foreground would be your primary and the one in the background would be your secondary. Here is a picture from Google to wit;
    Brettj3876 Thanks this.
  9. Ikamob01
    314
    195
    Dec 4, 2021
    Ok guys thanks for your inputs.
  10. Ridgeline
    22,749
    123,924
  11. Ikamob01
    314
    195
    Dec 4, 2021
