GVW and GVWR
Discussion in 'Questions From New Drivers' started by banatural, Apr 25, 2017.
  1. banatural
    banatural Bobtail Member
    If on a road and my GVWR is 60000lbs but local ordinance says must use truck routes if gvw is 44000lbs if my loads not full and under 44000lbs can I drive around town legally? 2 questions is gvw same as gvwr, and if not at capacity can I deviate off truck routes?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Stay on truck routes.
    Always.
    If you don't expect a policeman standing on your fuel tank talking about taking you into the local jail for a while for violating traffic control devices (Weight restricting signs...)
    AtticusRoad Thanks this.
  4. MACK E-6
    50,142
    239,542
    No, they are not the same.
    If a sign is posted for 44000 gvw and you only have one or two skids on board, you'll most likely be legal to use that road, cross the bridge, or what have you.
    On the other hand, if that sign says "GVWR" and the plate inside your door jamb reads a number higher than that, you won't be legal on those roads even when empty. The "R" for "rating" changes everything.
    Big Don, x1Heavy, AtticusRoad and 2 others Thank this.
  5. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Just to be sure....
    GVW is total weight
    Load + Empty Weight.
    It won't take a lot of weight on trailer to reach 44k.
  6. Ridgeline
    22,752
    124,031
    It don't matter, the word gross is on the sign so it is all the same. If it says 44K, then empty or full, it is your gross below 44k.
    x1Heavy Thanks this.
  7. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Actually gross simply means total. As in tare + net (vehicle + load)
    So gvw is simply what the cat scale ticket shows.
    gvwr is the max that truck can pull limited either by registration or mechanical limits. Usally 80k lbs for a common fleet flatbed or van.
  8. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Normally you will have 1 of several restrictions
    Trucks over x gvw. (Cant weight more than x)
    Axle weight restrictions (3 ton axle limit)
    Trucks over x gvwr (what the truck can handle)
  9. Moose1958
    Moose1958 Road Train Member
    15,298
    33,966
    Dec 17, 2010
    Williesburg, Virignia
    As a general Rule GVWR is not about anything operational about the rig. It is more about licensing and the operators CDL etc etc. Go by the actual loaded weight unless of course it exceeds the GVWR then you got a whole lot of other problems and need to get stopped ASAP.Just FYI there are some places where the overweight fines on bridges is 5 figures.
