Hailing hopper bottom 22.5 vs 24.5 ??
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by iamfargo, Apr 2, 2019.
  1. iamfargo
    iamfargo Light Load Member
    107
    22
    Feb 20, 2019
    So hauling in the Midwest and south east on my new tractor and trailer should I got with 24.5 inch wheels or 22.5 and should I go low pro or R rates tires .... please give advice and reason why ? Thanks
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Most where I am use 11R24.5 for the ground clearance, and hopper clearance. Especially if you are going out into the fields.
    I have 11R22.5
    iamfargo Thanks this.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Same size wheels on the trailer as truck, you can always use good used drives as trailer tires.
    iamfargo and Cat sdp Thank this.
  5. iamfargo
    107
    22
    Feb 20, 2019
    So go with 24.5?
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    If that's what you have on one or the other. It doesn't make that much of a difference really.
  7. rcelmo
    rcelmo Medium Load Member
    459
    1,986
    Mar 23, 2015
    I am not a big fan of low pro tires for off-road. Seems the tall rubber
    does better in muddy, low traction conditions.
    I would definitely keep trailer and tractor the same size. Half wore
    out steer tires will run a long time on the trailer.
    Some will run the low pro tires trying to get a lower ride height. With
    hopper bottom that is usually not a concern......unless running a tall side
    trailer. 11R24.5 would be my first choice.
  8. wore out
    wore out Numbered Classic
    17,432
    216,994
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I run tall 24's because the truck come with them. I have ran low pro 24's with a possum belly hopper and never had any trouble. (The mid 90's style timpte that the hoppers were really low and looked one piece though they weren't).
    Don't over think it drop it in the top pour it out the bottom that's really a there is to it.
    I do agree with the above statement same size on truck as trailer
    beastr123 and iamfargo Thank this.
  9. iamfargo
    107
    22
    Feb 20, 2019
    Roger that boss man is there a big weight difference in the two sizes tires with air ect I’m just trying to shed weight anyway possible
  10. beastr123
    beastr123 Road Train Member
    2,955
    24,246
    Jan 2, 2014
    Moose Jaw SK CAN
    drive tires 15# between 24.5 and 275/80/22.5
    trailer tires 10# between 24.5 and 275/80/22.5
  11. Truckermatt74
    Truckermatt74 Bobtail Member
    34
    25
    Mar 21, 2013
    Montana
    If your going off pavement like logging, bark/chips, dirt & ag do go 11R 24.5.
