Half a tank blues
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Ellijay, Oct 9, 2014.
  1. Ellijay
    Ellijay Bobtail Member
    39
    9
    Feb 16, 2014
    Anyone with first hand experience with this please speak. 2008 6.7 full delete mild EFI tune (80k since The D and tune. And has been running great since the tune and D now has 255k total. Well this week I done a east to west run and after the 4th fuell filter I come to realize it was doing after a half a tank only,new filter or not. Cutting out,no power and lots of black smoke,the emptier it gets the worse it gets. If I keep it at half a tank or more pulls like a train!! Wth ?
  3. xsetra
    xsetra Road Train Member
    5,200
    7,156
    Aug 21, 2011
    Maybe your tank vent is plugged.
  4. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Check the vent, do you have a secondary fuel filter?
  5. Ellijay
    39
    9
    Feb 16, 2014
    No the fuel supply and filters are all stock. Will check the vent out today.
  6. StrongArm
    StrongArm Light Load Member
    50
    11
    Apr 2, 2014
    New York, NY
    Bad fuel? Do you have a way to drain the tank? Drain the water separator? Just suggestions, I dont know too much about that motor.
  7. Ellijay
    39
    9
    Feb 16, 2014
    It started in Knoxville tn and did that all the way to southerner Cali and back,5000 + miles and five filters. I'm about to drop the tank as we speak,iv been told half a dozen times its only pickup tube broken or has a hole in it. I'll know in a hour.
    baha Thanks this.
  8. Ridgeline
    22,794
    125,034
  9. Ellijay
    39
    9
    Feb 16, 2014
    Really? ...
  10. Ridgeline
    22,794
    125,034
    Again what was deleted?
    EGR and DPF system??
    I wondered what else was done, like maybe a sump pickup on the tank, better plumbing form the tank to the fuel system?
    Sounds like you got a problem with the fuel pickup in the tank.
  11. Ellijay
    39
    9
    Feb 16, 2014
    i said full delete from the very beginning(you even highlighted it for me). But the fuel supply is all factory. it was a bad fuel cap believe it or not,was about to drop the tank when I read the cap vent could be stopped up so I took it off drove to parts store and has been running great since.
