hammer?
Discussion in 'Flatbed Trucking Forum' started by Chewy352, Jul 29, 2015.
  1. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I thought you used your forehead.
    Cluck Cluck and truckon Thank this.
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    That is only for hardwood dunnage.
    truckon and Cluck Cluck Thank this.
  4. The assortment of
    2' crow bar
    Cats paw
    Framers hammer
    16lb sledge on a 2' handle (BFH)
    Duplex nails
  5. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Cheapest one you can find. So, if someone gets ballzy and wants to start trouble, you won't be out much when you throw the evidence off a bridge.
  6. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    16 lb. Sledge. Comes in handy for steel loads and beating on the pointies to not rip the tarps. And whatever else.
    A couple of 90 degree bars with notches for pulling out nails.
    Claw hammer.
    All found at harbor freight.
  7. Pedigreed Bulldog
    7,737
    14,424
    May 7, 2011
    I keep a Vaughan 24oz framing hammer (made in USA) in the truck...prefer a straight hickory handle over the "ergonomic" bent handles so that it swings the same whether I'm hammering a nail or chipping at something with the claw. Hickory handle allows it to be used as a tire thumper, giving a better sound/feel than a synthetic or steel handle will provide.
    Simple solution: Don't miss the nail!
  8. MACK E-6
    50,105
    239,095
    Especially the ones with axe handles. ;)
  9. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
    Estwing or Vaughan both made in the USA. 20 ounce Straight claw, framing handle. Easy to pull nails from dunnage and can use the claw in the ratchet binder to hold while tightening.
  10. 77fib77
    77fib77 Road Train Member
    11,703
    77,350
    Jul 7, 2010
    St Louis
    I bought a 4lb sledge at harbor freight. It was as eight Bucks I couldn't pass it up.
