Hard starting when parked up hill
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bruce25, Jan 8, 2024.
  1. bruce25
    bruce25 Light Load Member
    150
    90
    Apr 16, 2014
    Every time I park the truck in my driveway which has incline truck has hard start problem. Even in summer it will crank for few sec but on flat or downhill it starts right away. Yesterday 18 deg no plug flat surface starts very quick today at home 25deg plugged had to crank it three times to get it started. I am thinking maybe something wrong with fuel lines or a pick-up tube in tanks. I got about quarter fuel in it haven't tried with full tanks anyone had any similar issues?
    2002 Pre emissions bk 12.7
  3. Rideandrepair
    17,575
    56,931
    Aug 8, 2015
    If the check valve on the head has a very minimal leak, I would imagine it could only leak on an uphill slope. Since fuel would run down out of the head. Not saying it’s your problem, just an idea. Other idea would be the slope at which the fuel lines run from tanks to T point. They should be on a constant rise, no high loop, or no low spots. However you want to describe it.
    bruce25 Thanks this.
  4. bruce25
    150
    90
    Apr 16, 2014
    Check valve on the back of the head is brand new two weeks old. This started happening last year was thinking of draining my devco and check it's check valve just in case. If all else fails I will have to check fuel lines make sure there is no small air leak that drains fuel back.
    Just a quick update parked truck downhill yesterday at 5pm just started it fired right away. If I find the problem will give an update
  5. bruce25
    150
    90
    Apr 16, 2014
    Update went out to drain fuel out of devco took cap of and it sucked fuel back to tanks. I new right then it was bad check valve. Took it off it was full of dirt cleaned it and all good now holding fuel without cap
    JB7 Thanks this.
