Harmonic balancer question.
Discussion in 'Volvo Forum' started by ErieMcDreary, Apr 17, 2020.
  1. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    394
    Dec 4, 2016
    Erie PA
    I can't find the answer through search;
    Is the balancer just bolted on to the front of the crank, or does it slide on the snout? The "for sale" ones I see all have 8 bolt holes that appear to bolt to the crank.
    2016 D13 575,000 miles, so it's due.
    I had heard from Volvo that wear is not an issue with them, but I am starting to get a vibration. Just had the steers balanced, that made it better.
    I had also heard that it's an internal balance.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    First it's called a Crank Shaft dampner, and yes Volvos are internal and thy are a serviceable item. Most shops will tell you thy never need replaced but thy aren't the ones who have to put up with the funky vibrations. Most trucks are fairly easy, just unbolt the old one and put the new one on. The Volvo is much more involved because it's internal.
  4. ErieMcDreary
    460
    394
    Dec 4, 2016
    Erie PA
    It has many names;). Sort of like aftercooler/intercooler, or turn signal/directional, or shifter/gear selector, or truck stop/travel center, or rest area/pickle park, etc., but we all know what we're referring to.
    I guess the main thing I wanted to know is if it's something external that I can change out myself, or something that the motor needs some disassembly for.
    stillwurkin Thanks this.
  5. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Bruce Mallison(sp) from pitts power has always said they should be replaced..think he said around 4 to 500k? Never looked at a volvo engine. Think most bolt on to the front of the crank. Its less $ than replacing a crankshaft.
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Rideandrepair Thanks this.
  7. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    I have replaced only 2 on D13. Customer request. No issues, they just wanted to replace with inframe. They said they saw no difference.
    Snailexpress, 062, D.Tibbitt and 3 others Thank this.
  8. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    I have never seen one replaced cuz it needed it going on 12 years working with volvo have seen a few ISX but never a volvo engine.
    062 and D.Tibbitt Thank this.
  9. Ridgeline
    22,720
    123,291
    They wear out, actually the rubber deteriorates and causes vibration issues.
    It should be looked at 500K and if they look ratty (the rubber), then replace it.
    Most mechanics are clueless.
    And it is a cheap fix to a problem that can cause issue for you down the road.
  10. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    well I beg to differ with your opinion seeing as there is no rubber on most heavy use highway engines they are all viscous fluid types with counterweight inside.
