Has anybody seen this?
Discussion in 'CB Radio Forum' started by rabbiporkchop, Feb 8, 2018.
  1. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
  3. Powder Joints
    7,988
    8,407
    Sep 25, 2007
    Rosamond, SoCal
    I have been a long time proponent of cable tuning, in the case of repeaters you can tune them for peak SNR , the cables between the cavities are just as important, As in when setting up master receive and transmit systems.
    We would use a RF sweep generator and a Specturm analizer, and a Sinader coupled to the receiver.
    rabbiporkchop Thanks this.
  4. Ridgeline
    22,730
    123,548
    You two know what the application is and how it matters when in hf it doesn't?
  5. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    Rf is rf regardless of application. Others have noticed something similar. This was the first published research I found though. I find this stuff fascinating.
    Why would it not matter when clearly at lower frequencies precise measurement would be easier to obtain since the wavelength is much greater and at higher frequencies 2 mm of cable would make a drastic difference but almost no difference at lower frequencies?
    I think it would be pretty interesting to sweep 11 meters of cable at 27 megahertz to see what snr fluctuations we might find within that length of cable, and at what phase angle they occur.
  6. Scvready
    Scvready Light Load Member
    231
    173
    Dec 16, 2017
    Louisiana
    Nothing here makes sense so let me come to confuse a bit more. Low frequencies travel longer distances
  7. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    I'd be curious to see the test results from the best to worst results to see if it matches the 25% to 30% improvement at certain spots.
  8. Ridgeline
    22,730
    123,548
    I thought you knew how rf works?
    It matters what frequency they are operating, the formulas are a clue. They are in the uhf/microwave region and as powder hinted at when he did work repeaters, cable lengths mattered.
    Microwaves behave different than hf/my, especially in regards of noise and feedlines.
    Many of these things don't matter when it comes to lower frequencies like hf.
    By the way, spin noise is discussed in nuke research, I think it was discovered back in the 80's in Germany or Austria.
