Hauling steel coils
Discussion in 'Experienced Truckers' Advice' started by Eight433, Jul 31, 2009.
  1. Eight433
    Eight433 Light Load Member
    100
    23
    Aug 12, 2006
    I have a gig lined up driving a 2006 Freightliner Columbia with a 525 kitty cat and a trailer that i believe is set up much like this one. [​IMG]
    now, i AM Licensed for doubles, but have not pulled them. being that they are 5th wheel doubles and not pintle hook/converter dolly wiggle wagons, I am not worried. I have experience with 6 and 8 axle dry van trailers with 3 air operated lift axles, so I am not phased by that either. However, I have always heard horror stories about hauling steel coils because they are so top heavy. Is there really that big of a trick to it or is it pretty much keep the load chained down really good and avoid swerving and over correcting? I have also towed semi trucks using a 5th wheel wrecker and that was pretty much the deal with them. Wind will push your towed truck into the next county, and if you over corrected you would BOTH end up in the next county :biggrin_2552: Pulling a truck witn only its 2 front wheels and weak suspension on the ground can make the 13 foot tall truck start swaying pretty good if you are not steady with the steering wheel.
    Anyways, any advice an experienced steel hauler can give me would be greatly apprieciated!
  3. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    The trick with coils is knowing how to secure. You need to know how to load. On shot gun I criss cross 2 chains and horse shoe the rest. I use trip chains with coil blocks. Then I throw 2 straps over the top. I use coil racks, beveled boards, coil pads, edge protectors, friction mats are nice if you have them.
    On suicide you can not criss cross.
    Eye to the sky I use trip chains, plus secure over the top.
    Pickled coils are very dangerous. I use a choke chain on them.
    Most places if the weather permits you put a couple chains on and move outside to finish securing and tarping. Be gentle on your motion. I have seen a few coils not make it to the tarping area.
  4. Carolina Thunder
    Carolina Thunder Medium Load Member
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    "is it pretty much keep the load chained down really good and avoid swerving and over correcting?"
    Thats really what it comes down to and if you have to spend your own money to buy more chains then do so. On those big coils you can never have to many chains because i have seen a coil come lose when the driver hit his brakes really hard because the coil was nto chained corectly. It rolled across the cab of the truck and onto a car in front of him,flatened the cab and the car in front of him. Killing them both.
    I did it for a year and that was to long!
  5. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Using commonsense when driving is just as important as securement. Your not going to fly around corners, ramps, turns,...etc
  6. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    Basically what the other guys have said, but with this added. Straps (or chains if allowed) must be over every coil. This is a DOT rule and a very good one at that. The second note that I'm surprised Les2 didn't make is when you secure a coil place the chains as close to the coil as possible. Many companies are showing drivers to run the chains out about 2-3 feet from the fron or back of the coil before they are hooked to a tie down. This is where things can turn ugly in a heavy braking situation. If you can 2-3 feet away that coil has room to start moving. It will move no matter how many chains or straps you have on it since there is only the downward pressure of the chains and no forward or rearward pressure. Use common sense and watch guys that have been doing it for years.
  7. TripleSix
    133,362
    Doesnt matter what you have on your wagon. You have to be smooth on all your inputs. Jerk a steering wheel with a heavy load in a van and you have a good chance of putting the rig on its side.
    volvodriver01 Thanks this.
  8. Eight433
    100
    23
    Aug 12, 2006
    thank you for your input but this thread is about hauling steel coils specifically. I have plenty dry van experience, and it does not get much heavier in a dry van than an 8 axle manac with 95,000 lbs of brake rotors.
  9. TripleSix
    133,362
    Friend, I understand that this thread was about hauling coils. Yes, the big coils are top heavy (especially if theyre tall and thin). My point is to practice being smooth with your driving inputs regardless of what youre hauling.
    Had to go pick a supercoil up in BowlingGreen,KY. Driver pulled over onto the shoulder of a road to take a piss. Coil leaned over and put the entire rig into a ditch. They cut the chains and lifted the truck out of the ditch and brough a crane there to lift the coil onto my trailer. Except for a broken leg, the driver was okay.
  10. Ridgerunner665
    Ridgerunner665 Road Train Member
    2,138
    1,064
    Apr 27, 2009
    Notarps has done told you everything I know...
    I've hauled a few coils and unlike alot of others I prefer loading them "eye to the side" (also known as "suicide") because it takes more of an angle to pivot it over center when they are loaded that way (in other words...they don't roll you over as easy). But sometimes the receiver specifies which way they want it loaded...so far I've been lucky and have been able to load them eye to the side every time.
    Notarps mentioned "pickled coils" (coils soaked in oil) and choke chains and he's right, this is a MUST. The same goes for slitted coils...use a choke chain and no coil pads on the timbers.
    Watch your speed and drive smooth in turns or curves...no jerking the steering wheel. USE ENOUGH CHAINS...can't stress that one enough. At Maverick they rate the chains at 8,000 lbs each...thats 5 chains on a 40,000 lb. coil. But we never use less than 3 chains on any coil (regardless of weight).
    And like TripleSix just mentioned...be careful of any low places when you pull off the road (or anywhere else)
  11. Ridgerunner665
    2,138
    1,064
    Apr 27, 2009
    You said "over" every coil...if you mean over the top. That rule only applies to coils loaded "shotgun". You don't have to put anything over the top of a coil loaded eye to the side.
    rodzilla Thanks this.
