Have a quick question Sirio Performer antenna?
Discussion in 'CB Radio Forum' started by Squirrel Bait, Sep 3, 2022.
  1. Squirrel Bait
    Squirrel Bait Bobtail Member
    8
    10
    Mar 17, 2022
    W900 , Changed out my antenna today from a Stryker SA-2A to a Sirio Performer with a new bracket, screwed the coax back in , I turned the switch on to roll the window up , the radio powered up but was really low volume from what it usually sounds like. I actually had to turn the volume up louder to hear it. I didn't have time to put the meter on it today so I just turned it off. Why would just putting a different antenna on make the volume do that?
  3. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Are you sure you didn't accidently bump the volume
  4. Squirrel Bait
    8
    10
    Mar 17, 2022
    No don't think I did , all I did was turned the switch on to roll the window down and turned it off. Changed the antenna out, and turned the switch back on to roll the window up. When the radio powered up it just wasn't as loud as before. I don't think I even touched the radio.
  5. Squirrel Bait
    8
    10
    Mar 17, 2022
    In the morning, I'm going to go down the road to a clear spot and hook the meter to it. I got a power line right over my yard, so I can't do it here.
  6. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Make sure RF Gain is turned up
  7. Ridgeline
    22,741
    123,654
    Don’t be so critical, it really doesn’t make much difference, take the readings and then later on test it again, if it is consistent (within 10%) then believe the reading.
    Reason for edit: Fixed typo
  8. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    Generally a new installed antenna needs to be shortened or lengthened to match the radio. It's best to use an external SWR meter or antenna analyzer to do this. I've seen antennas that are badly mis-matched for the frequency you are on, cause low audio (noise floor) in the radio. Or it can be caused by a damaged antenna.
  9. Squirrel Bait
    8
    10
    Mar 17, 2022
    Well I went and checked, SWR was through the roof, so was going to remove the Sirio until I can get a antenna analyzer on it, the end of the coax just didn't seem right so I put my Stryker back on and new coax . Thanks for the replies.
  10. wolverine11
    wolverine11 Road Train Member
    1,628
    1,234
    Apr 1, 2015
    And the result with the new coax and Stryker ?
  11. Squirrel Bait
    8
    10
    Mar 17, 2022
    Well it's back down to 1.6 and the volume back up to normal. I believe it was the coax in conjunction with the new un-adjusted antenna.
