Hazmat and bol
Discussion in 'Hazmat Trucking Forum' started by tom obsonh, Jul 3, 2019.
  1. tom obsonh
    tom obsonh Bobtail Member
    10
    5
    May 22, 2015
    If a bol is marked hazmat do you need an endorsement?i work for a retail company and i do have my endorsement so i understand placarding rules.we haul pool chemicals in consumer commodity packages do i believe this would be orm d.however they insist on marking it a hazmat on the bills.i think that is wrong but you cant tell them anything.
  3. haz-matguru
    haz-matguru Road Train Member
    2,933
    4,538
    Feb 18, 2012
    Some levels of hazmat can be transported with out placards. Depending on the quantity of it. And others require placards at any amount.
    Look up the hazmat segregation chart to make sure. However the shipper should know this and supply the transporter with placards if you dint have any.
  4. tom obsonh
    10
    5
    May 22, 2015
    My question is if a dot officer looks at the bill and its marked as hazmat does it open a can of worms.these are consumer commodity packages in one or two pallets mixed with general freight.i believe it should be orm d which does not require placarding.
  5. tom obsonh
    10
    5
    May 22, 2015
    And of course our company should know this but apparently they dont.
  6. tom obsonh
    10
    5
    May 22, 2015
    The commodity is 12.5 percent sodium hypochlorite in one gallon bottles packaged in a case.
  7. Diesel Dave
    9,710
    33,128
    Jan 20, 2010
    Hesperia, Ca.
    Any Hazmat materials is mandatory to be marked on the BOL. I believed it’s anything over 1000 lbs. But regardless, it should be stated.
  8. tom obsonh
    10
    5
    May 22, 2015
  9. tom obsonh
    10
    5
    May 22, 2015
    And no they are not supplying us placards but it is marked hazmat on the bills.
  10. tom obsonh
    10
    5
    May 22, 2015
    Ok so you can be marked on bol as hazmat but still not be required to placard if its under 1001 lbs.i believe our freight is orm d and should be marked as such.
    Cabinover101 Thanks this.
  11. MACK E-6
    50,089
    238,967
    All hazmat has to be listed, even if it’s limited quantity packaging which wouldn’t need placards, but that would also have to be stated on the BOL.
