Hazmat border crossing
Discussion in 'Canadian Truckers Forum' started by Redtwin, May 28, 2021.
  1. Redtwin
    Redtwin Road Train Member
    5,525
    7,704
    Aug 17, 2012
    PBC, FL
    I'm scheduled to haul a hazmat load from the US to Canada. Are there any specific rules that I need to know about Canada that differ from the US?.
  3. upnorthwpg
    upnorthwpg Road Train Member
    1,829
    2,792
    Sep 23, 2011
    Depends on the load and the requirements. Your average hazmat load, not really. Don’t need to stop at rail crossings like you do stateside.
  4. Redtwin
    5,525
    7,704
    Aug 17, 2012
    PBC, FL
    It's basic flammable, nothing particularly nasty. Good to know about the railroad crossings. I haven't been to this customer yet, but other nonhazmat loads that I have hauled take me over rail tracks going across the trans canadian/20 in Quebec.
    I can imagine the chaos I would cause coming to a full stop on a 62 MPH highway. :eek:
  5. peterd
    peterd Medium Load Member
    349
    365
    Jan 7, 2012
    St.Catharines ON
    You have to stop for R/R crossings in Quebec unless they are exempt.
    Magoo1968 and Redtwin Thank this.
  6. Redtwin
    5,525
    7,704
    Aug 17, 2012
    PBC, FL
    I will check if it has signage saying it is exempt...assuming I can figure out the French.
  7. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    Check online to see if there is any restrictions on where you are crossing.
    Ambassador bridge is no hazmat.
    There is one class that is restricted at Bluewater.
    And I think you are supposed to notify the peace bridge about a hour before you cross.
    misterG and Redtwin Thank this.
  8. Redtwin
    5,525
    7,704
    Aug 17, 2012
    PBC, FL
    Thanks, it was a land crossing didn't see any restrictions posted at the crossing. Made it to the customer without issue, only one RR crossing on a side street which I stopped for, didn't check if it was exempt or not.
    mudflap77 Thanks this.
  9. mudflap77
    864
    1,314
    Oct 11, 2010
    Yeah it's not really the border that has a problem with hazmat. More of bridges and tunnels to get to some of them. Always a good idea to do a Google search to make sure there is nothing special about crossing somewhere with hazmat. Last thing you want is any undo trouble hauling hazmat.
    Petro51, misterG and Redtwin Thank this.
  10. '88K100
    '88K100 Road Train Member
    1,490
    3,586
    Aug 23, 2020
    You can't use the tunnel in Montreal with dangerous goods on board. Not sure if its still the Fontaine tunnel, they have a way of changing names of main roads etc after a local election. Bridges are not a issue.
    Redtwin Thanks this.
  11. Petro51
    Petro51 Bobtail Member
    5
    Mar 18, 2021
    They opened Ambasador Bridge, Windsor-Detroit for few months ago for some hazmat freight. I'm puling right now an automotive load of door assemblys with airbags , pyrotechnic cartridges ,Class 9 I'll cross in Windsor . I've been crosding this loads for many years via Port Huron/Sarnia only. Years ago I used to pull garbage from Ontario to Michigan , we could exit in Port Huron only, and only return empty through Windsor, but over past months I have seen garbage trucks entering USA in Detroit. A couple of weeks ago in came into Canada with a load of corrosive ckeaning materials, not sure what hazmat class, and had to go via Sarnia.
