Hazmat H or X
Discussion in 'Questions From New Drivers' started by Dunskin, Jan 7, 2009.
  1. Dunskin
    Dunskin Bobtail Member
    11
    Atlanta, Ga
    I've been looking all over the nets to find out which one I need to put on my TSA Application Background check and still can't find out which one I need. Can anyone point me in the right direction.
    So far I've just heard that H is for some states endorsement and they use X for other states endorsements. And if that's the only difference, How can I find out which one my state uses? Georgia by the way.
    thanks.
  3. IrunU
    IrunU Medium Load Member
    309
    212
    Nov 17, 2008
    Outside the fire
    H is Haz Mat X is Haz Mat plus tanker
    Baack, Kabar and oldcornbinder Thank this.
  4. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    DQ is right, I have X because I have haz plus tanker.
  5. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    Unless I am missing the point to your question here, ??????
    Why don't you look on your CDL and see what endorsement it has on it?
    The other two posters are right as to what the designations mean.
  6. Dunskin
    11
    Atlanta, Ga
    Well I don't have the endorsement yet. I'm filling out paper work for the background check that's required to get the endorsement.
    And thanks for the answers guy! So in other words if all I'm hauling is dry vans that might possibly need placards it's "H" and if I'm driving tanks with placards its "X"?
  7. davan2004
    davan2004 Light Load Member
    213
    28
    Dec 10, 2008
    Warren, MI
    I would put H. When i applied for My Hazmat I put H for the TSA application. When I sent to Secretary State (Michigan) to take hazmat test, I just spur of the moment went and took the tanker test as well. I ended up with X on my license afterwards.
  8. Dunskin
    11
    Atlanta, Ga
    Sweet, I start with Crete Carrier Corp on the 19th and I need to get my background check started by then, so I wanted to go ahead and do it.
    Thanks again for the help guys.
  9. crazyhermit
    crazyhermit Bobtail Member
    6
    Dec 18, 2008
    SW Mississippi
    Don't wait too long - go ahead and get it started. It usually takes several weeks to get the checks back, depending on the state and the number of apps in the system at the time. Mine took about 3 weeks to get back.
  10. Dunskin
    11
    Atlanta, Ga
    Yeah, I'm going this Friday to get it done. Crete said as long as I have my receipt showing that I've got the process started is good enough for them.
  11. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    OK, I understand now. Sorry for being so dense. . .:biggrin_2552:
    Well, yes, more or less. If you have the X endorsement, then you are good for tankers or dry vans with hazmat. If you just have the H, then dry van is all you can do.
    Seems to me like it is just as easy to get the X right from the get-go, then you can use it as you need it. At least that is what I did. I've had the X endorsement since I first got my CDL. I've never been a tanker yanker, but I have hauled a lot of hazmat with dry vans. But the point is, that should it come up, I already have the endorsement.
    And while right now, I am listing myself as an "ex-trucker," who knows what the future will bring. . .:biggrin_25520:
    With the economy the way it is I may not be able to be retarded er retired for ever. . .:biggrin_2552:
