Hazmat Question
Discussion in 'Trucking Industry Regulations' started by bwalk, Apr 3, 2010.
  1. bwalk
    bwalk Bobtail Member
    4
    Apr 3, 2010
    Hello everyone,
    I'm a newbie here, and not a trucker so pardon my ignorance. I have a serious question. My employer utilizes the services of a vendor who transports a hazmat chemical across state lines. PA-NJ. This chemical is necessary to perform the service. The vendor stores the chemical in their original, labeled containers (usually 2 to 3 plastic gallon jugs), but they are in the back of his pickup truck which has no hazmat signage on it. Is this legal?
    Without naming the chemical, all I can say is that the danger in handling it is extreme, as skin saturation with the chemical in areas of only 25 square inches may be fatal. High concentrations of this chemical will also quickly destroy the corneas of the eyes and decalcify bones.
    Any feedback would help. Thanks.
  3. redsoxfan4ever
    redsoxfan4ever Light Load Member
    61
    11
    Sep 19, 2009
    webster,mass
    depending on what it is...you need to check the hazmat table to find out if it needs to be placarded...the hazmat table will give you all the info you need
  4. Allow Me.
    10,794
    12,691
    May 28, 2009
    Rancho Mirage, Ca.
    Sounds like some nasty stuff. In a 53' trailer, you can haul a minimal amount of Haz without using placards,( I believe it's 1000 lbs). Or, it used to be that. I'll admit, I don't have a Haz endorsement, so I am not current on the regs. But consider all vehicles have gas tanks and are pretty much safe until they crash and then possibly blow.
  5. redsoxfan4ever
    61
    11
    Sep 19, 2009
    webster,mass
    you are close..its 1001 lbs...but some stuff has to be placarded no matter how much it is...best to check the regulations..
    Freebird135 Thanks this.
  6. statikuz
    statikuz Medium Load Member
    401
    140
    Jun 22, 2009
    Reno Nevada
    If it's explosive, poison gas / inhalation hazard, dangerous when wet, or radioactive, it has to be placarded in any amount. Everything else has to be 1001 lbs. or more like redsox said.
    Sounds like the chemical you describe is hydrofluoric acid - which is Class 8 Corrosive.
    I'm not an expert on the packing groups and exceptions and whatnot though.
    heyns57 Thanks this.
  7. bwalk
    4
    Apr 3, 2010
    Good guess! It is HF. Thanks for the info!
  8. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    You need to check the references. It could even be hazardous substance which is different than hazardous materials. You never want to guess.
  9. statikuz
    401
    140
    Jun 22, 2009
    Reno Nevada
    According to the LOHSARQ (like that? :)) the RQ of HF is 100 lbs. Density of HF is around 10 lbs. per gallon so it doesn't look like a few jugs of it is a RQ.
  10. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    Well statikuz, if this driver is hauling (unless I'm incorrect, and I have been before) 2-3, (1) gallon containers that would be about 20-30 lbs.
    However if they are 2-3 gallon's per container that another problem right there.
    Than your talking about 20-30 lbs per container.
    IMO, some clarification might be needed on this matter as to how many containers and the actual size of the container.
  11. dr5169
    dr5169 Medium Load Member
    324
    97
    Dec 1, 2008
    chicago,il
    Thanks for this info....i knew there was some stuff that had to be placarded no matter what...your post cleared it up...
