Head Gasket ?
Discussion in 'Ask An Owner Operator' started by Luke700, Jul 30, 2021.
  1. Luke700
    Luke700 Light Load Member
    57
    26
    Oct 14, 2019
    When I take off my coolant cap theres high pressure and coolant splashes all over the engine. The truck doesn’t blow smoke. Oil don’t mix with coolant. Truck doesn’t overheat and it drives fine. There’s a few codes on the truck I haven’t scan yet. Besides the air compressor what else could cause this? Thanks
  3. AModelCat
    165,294
    Well the cooling system is pressurized so if you're opening the rad cap when the cooling system is hot (or even just warm) it'll spill out. Hotter it is, the more it'll spray.
  4. bad-luck
    bad-luck Road Train Member
    3,457
    6,380
    Nov 16, 2013
    Baltimore, Maryland
    The system is pressurized. Look at the top of your radiator cap. It will have pounds listed on it. For example lets say its 13lbs, it will hold 13psi , when it goes over 13psi it will come out the overflow tube. A sign of a bad head gasket would be, your pushing coolant out on the ground through the overflow tube, and having to continuously add coolant.
  5. Luke700
    57
    26
    Oct 14, 2019
    Sorry I meant to say the reservoir cap.
    sorry meant to say reservoir cap.
    Rideandrepair Thanks this.
  6. AModelCat
    165,294
    Still pressurized.
  7. Luke700
    57
    26
    Oct 14, 2019
    Appreciate it. Any ideas as to what might be the issue?
  8. AModelCat
    165,294
  9. Antinomian
    Antinomian Road Train Member
    2,193
    3,492
    Feb 17, 2013
    What kind of engine?
    Does it have EGR? That's the most common source of excessive pressure if the engine has EGR. Do you see bubbles in the recovery tank when the engine is running?
    Are you loosing any coolant?
    Take an oil sample and check for coolant products (sodium and potassium) in the oil.
    Jarhed1964 Thanks this.
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Is the engine hot or cold when you’re taking the cap off.
    feldsforever Thanks this.
  11. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Do a fluid test and see if it changes colors. Harbor Freight sells a kit to do it.
