Headaches
Discussion in 'Flatbed Trucking Forum' started by Hogleg, Mar 8, 2017.
  1. Hogleg
    Hogleg Medium Load Member
    311
    258
    Nov 20, 2016
    Salem, Illinois
    We are going to add a flatbed to our fleet for local hauling. To that end, we have a nice headache rack that was on our Peterbilt. Fit up good and tight to the cab. On the International there is a single exhaust that is bolted to the frame aft of the sleeper. This interferes with the headache mounting and has to mount further back due to this. Looks bad. Thought maybe a trailer with a headache mounted on the front of the trailer may be a solution. Do they make a headache with an offset for this sort of stack arrangement?
    Advice?
    John
  3. Razororange
    Razororange Road Train Member
    2,722
    25,888
    Dec 20, 2011
    Milwaukee, WI
    Yes, there are racks built with one side missing to work around single stacks on the back of the sleeper.
    I see that your profile lists you as being located in Salem, IL. If that's right then you should give Tri City Canvas Products over in Granite City a call. They are great to work with and have reasonable prices.
    If they don't have what you want in stock they can order it.
    Here's their website:
    Http://www.everythingforyourflatbed.com
    Phone number there is
    1-800-966-1662
    Lepton1, snowman_w900, Oxbow and 2 others Thank this.
  4. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Put a weed burner exhaust on
    Razororange Thanks this.
  5. Razororange
    2,722
    25,888
    Dec 20, 2011
    Milwaukee, WI
    This is an option as well. Looks better than the single stack too.
    snowman_w900, MJ1657 and Peelsession Thank this.
  6. Peelsession
    Peelsession Light Load Member
    197
    389
    Feb 13, 2016
    Sioux City, IA
    Bonus: No smoke tarp needed!
  7. Espressolane
    18,717
    117,366
    Headache rack or chain rack are alternate names for a cab protector.
    A Headboard, headerboard or bulkhead would be the ones mounted to the front of the trailer.
    You can have either or both.
    They are not required for most flatbed freight with in the DOT rules. Now what a shipper may require is a whole different can of worms, and not something to get into here.
    A cab protector does not have to mount within a set distance from the cab. As you have described, having a single stack between the cab and the cab protector is nothing new. Have had ones like that for years. While it may not be aesthetically appealing as you would like, it works. It does require mounting the protector a farther back.
    If you do a google search on " cab protctor for semi trucks"
    you should get a number of links. Merrit, protech are a few quality manufacturers.
    x1Heavy and Razororange Thank this.
  8. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Straight pipe it. Rack can be within 8 inches or so then.
    SoDel Thanks this.
  9. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    What?
    mslashbar Thanks this.
  10. RustyBolt
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    He's mounting a headache rack on an international. The mufflers are huge and cause one to mount the rack 1.5 feet off the sleeper. Straight pipe it and it can be moved closer to the sleeper by a bunch.
    MJ1657 Thanks this.
  11. Ruthless
    Ruthless Road Train Member
    9,193
    91,313
    Aug 28, 2010
    The City.
    Wha'd he say
    TripleSix and MJ1657 Thank this.
