Headlight issues 1991 379
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Coolbreezin, Feb 3, 2020.
  1. Coolbreezin
    Coolbreezin Medium Load Member
    409
    439
    Jun 11, 2016
    Florida
    Hello all. I have a 1991 379. I have four individual headlights and all seemed well until recently. Both low beams work but when I turn my high beams on the driver side both lights don't work, but on my passenger side both lights do work. Any suggestions where I should start looking?
  3. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    Put two new lights in the driver side
    062, Bean Jr. and AModelCat Thank this.
  4. Ridgeline
    22,726
    123,456
    Check the wiring harness first, the one that goes to the lights on the hood from the frame, these wires flex every time you open the hood.
  5. Coolbreezin
    409
    439
    Jun 11, 2016
    Florida
    Will do. Thank you Ridgeline.
  6. Coolbreezin
    409
    439
    Jun 11, 2016
    Florida
    And how is this supposed to help?
  7. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    Because your bright light works off your dim light that’s why there’s three prongs on your dim light and two prongs on your bright light you asked I just gave my two cents if you don’t want to use it that’s fine with me!
    If it doesn’t work I’m sorry I have no other suggestions , Nothing ventured nothing gained!
  8. Coolbreezin
    409
    439
    Jun 11, 2016
    Florida
    Deere Hunter, your initial post sounded sarcastic. And it is common in forums for people to post things like that, so that's how I took it. Thank you for your information.
  9. Coolbreezin
    409
    439
    Jun 11, 2016
    Florida
    Problem found and fixed, broken wire. What a mess to work through.
  10. Deere hunter
    2,121
    10,024
    Aug 5, 2017
    Shallowater Texas
    No problem been running 379’s for year have had that and other problems similar so if no wiring problems that’s usually the culprit!!!
    God Bless and happy trails!
