headlight problems
Discussion in 'Peterbilt Forum' started by coulds, Jun 12, 2013.
  1. coulds
    coulds Bobtail Member
    24
    Richmond,Va
    When i turn headlights on low beam my high beam are on but I have checked all the wiring,changed lights new plugs and still samething any help would be gladly appreciated.
  3. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    What year/model?
  4. coulds
    24
    Richmond,Va
    its a 1994 379 pete
  5. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    Check for corrosion in the fuse box, quite common on Pete's. And check relays.
    coulds Thanks this.
  6. coulds
    24
    Richmond,Va
    when you say in fuse do you mean behind ?
  7. Sublime
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    Everywhere. We've had them with green stuff growing where you could see it and also on the backside. But check relays first, we've had some that at a casual glance look good on the outside but are junk on the inside.
    coulds Thanks this.
  8. coulds
    24
    Richmond,Va
    thanks I will check everything
  9. Luwi67
    Luwi67 Heavy Load Member
    751
    485
    Oct 24, 2012
    Long island
    Find a solution yet?
