Headlight problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kwlogger, May 25, 2023.
  1. Kwlogger
    Kwlogger Bobtail Member
    May 25, 2023
    2004 kenworth w900L headslights and turn signal lights on the hood do not turn on. Marker lights from the cab to the end of the truck work good still. I check the battery box no bad wires, checked fuse panel and relays, checked turn signal switch high beam indicator will come on but lights do not turn on. Rear blinkers only work on switch. Whats my problem? Stranded until daylight.
  3. skallagrime
    skallagrime Road Train Member
    3,854
    9,926
    Apr 10, 2012
    Indiana
    Open hood, drivers side, look for the wire connectors, sounds like hood harness has been unplugged.
    If your brights dash light didnt come on i'd say the physical headlight switch was dead. Worth just shorting the wires behind it to verify it isnt that switch
    blairandgretchen and Oxbow Thank this.
  4. Kwlogger
    May 25, 2023
    Hood harness on both sides cleaned and new switch put in still nothing only the dash lights turn still. Traced wires to find a rub spot and still no signs of damage
    blairandgretchen Thanks this.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    Suspect a bad ground because it is on multiple different power circuits. Flasher does not work because there are not enough lights, amperage draw , for the flasher to function.
    Years slip away from me but can you post a pic of the fire wall on the left front? I do not want to waste time talking about the wrong truck.
  6. Zethull
    Zethull Bobtail Member
    48
    21
    May 26, 2023
    KY
    Sounds like a ground wire
