Hearing a pop and then a pull left
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gunner75, Jun 19, 2016.
  1. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    It doesn't happen often, but there have been a few times that when i press the brakes harder than normal ive heard a pop or bang, then the steering wheel wants to pull left. Ive looked around the brakes and I'm not seeing anything out of the normal looks, ,what am i missing? My trucks going into the shop tomorrow for the ac system is inoperable, plus im having the clutch adjusted. What do i need to tell the shop when they ask?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. the ft. springs for a broken tie bolt
  4. 062
    062 Road Train Member
    6,352
    34,037
    Oct 20, 2013
    The pull to the left could be a problem with the right brake. Possibly caming over,broke spider,cam bushing gone.
  5. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I would check hub bearings also.
  6. Gunner75
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    I did check for that and nothing out of the ordinary
  7. Gunner75
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    I just talked with one of our other drivers and he's saying the brake jammer might be bad as well
  8. 062
    6,352
    34,037
    Oct 20, 2013
    What year and make? Seems like peterbilt had a problem with u-bolts on 13 or 14 579
  9. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Brake jammer? The nut behind the wheel?
    I've been to a few Freightliner shops about this problem. They can't find out what's wrong... sucks in the winter when it wants to pull to one side before it pops, and then wants to straighten out.
  10. DrFlush
    DrFlush Road Train Member
    1,297
    2,707
    Mar 22, 2011
    Upstate NY
    My Prostar did that once I a while also, found the brake lining cracked on both sides of the steer axle, had new brakes and drums installed and hasn't done it since.
  11. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    The tie bolt goes thru all of the ft. springs in the center of the springs the head of the tie bolt sticks thru into the steel ft. axle no part of it shows, you can ck. to see if the ft. axle is moving by looking for marks on axle under U/bolts where its been sliding back in forth on the springs, or you can roll down window an move truck then step on brake while sticking head out window and watching ft. end move when you stab on your brakes if its the drivers side get a helper to watch the R. side for you?
    BoxCarKidd Thanks this.
