Heat In Transit info
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by 19d, Feb 27, 2017.
  1. 19d
    19d Road Train Member
    1,290
    1,216
    Jan 12, 2016
    Sanford NC
    Hey I've done a lot HIT loads, but I'm pretty sure I hook up and run HIT a lot when I would've been ok to not run HIT on the load. So the info I need from ya more experienced chemical haulers is this. How much will a load drop temperature? I would like ruff estimates of say 24 hours in 30 degree weather , 70 to 80 degree etc.. and like when I do the Wyoming or South Dakota runs when it's 0 burrr cold. I really appreciate any info u can give me
  3. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    You might lose 5 maybe 10 depending on how cold it is outside
  4. 19d
    1,290
    1,216
    Jan 12, 2016
    Sanford NC
    Like this load I'm gonna leave with this evening headed to Minneapolis has to be between 110 and 180 and guy said it's 130 in his tank. I unload Wednesday afternoon now if I push super hard, need make it their by 3pm Wednesday. I might not need run hit, but I did hook lines up and charged trailer up already so I'm good to go either way
  5. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    I don't know anything about tankers but, if you went through the trouble to hook it up why not use it?
  6. 19d
    1,290
    1,216
    Jan 12, 2016
    Sanford NC
    I will be Useing it.. just getting info for future loads from more experienced with hit than myself. I'm gonna have to get this load steamed anyway. Loaded me at 100 degrees and it delivers at 110 to 180
  7. ncdriver1
    ncdriver1 Road Train Member
    1,106
    1,252
    Dec 3, 2012
    Unless you are hauling the same product in the same trailer its always going to be a different rate of loss. Some trailers have really good insulation and some products have a high specific heat and you wont need to worry about temperature loss.
    I got loaded last Saturday for a Monday delivery, loaded @120F, delivery got delayed until Wednesday afternoon (grrrr) and the product temp had only dropped to 105F. No HIT and no steam and air temps below 32F all 5 days. It was a thick product that held its heat really well.
    19d Thanks this.
  8. 19d
    1,290
    1,216
    Jan 12, 2016
    Sanford NC
    Thx the product I'm almost finally done with having loaded is real thick and the temp gauge went up on it to 119, so I will be able keep it above 110 easy.. glad I don't have to get steamed. I got Hit hooked up and running. I'm over 11 hours at this Lubrizol plant and bout sick of this place today
  9. ChicagoJohn
    ChicagoJohn Road Train Member
    2,390
    2,755
    Jan 14, 2016
    Chicago
    Like @ncdriver1 said It all depends on the tanks insulation. I used to haul epoxy a lot. We would steam to 160° and I would run Chicago to Cincinnati leaving in the afternoon and delivering cinci in the morning and I'd lose as much as 10° in a MC407. They were older trailers and a little beat up, so the heat loss was greater then what a newer tank would be. Knowing something at all about the equipment I've seen your company run, I'd say you're in the same boat.
    @p608 it can be a drag on the coolant system making your motor run cold. If the system wasn't flushed, it can also contaminant your coolant. It won't heat the product, but it can slow the speed at which it cools.
    Btw, I've never heard it said "heat in transient". Everyone I've worked for calls it "intransit heat " that must be a SNI thing.
  10. ethos
    ethos Trucker Forum STAFF Staff Member
    4,294
    14,387
    Mar 3, 2013
    Fort Worth
    It's impossible to answer. Every product and trailer is different.
    ChicagoJohn Thanks this.
  11. mustang190
    mustang190 Road Train Member
    2,896
    6,260
    Jan 18, 2011
    Florida Panhandle
    Transit heat will not raise the product temp from 100 degrees to 180, unless you. Stay on it for a month! Yo will need to get on steam.
    wis bang and ChicagoJohn Thank this.
