Heater hose routing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cat 03, Aug 7, 2023.
  1. cat 03
    cat 03 Bobtail Member
    24
    8
    Mar 22, 2013
    I have a 1997 pete with 3406e can I use either port on the back of the water pump for heater hose position. Can I move the hose outlet from the rear of the block to one of the pipe plugs on the oil cooler. Which way does it flow out of waterpump to firewall then back into the block or block to firewall then into the ports on rear of water pump
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Question 1: Yes
    Question 2: No
    Question 3: From the block or top of head. To the water cut off valve, through the heater core and back to the water pump.
    cat 03, Rideandrepair and Magoo1968 Thank this.
