Heater on 579..
Discussion in 'Peterbilt Forum' started by drvrtech77, Jan 24, 2019.
  1. drvrtech77
    drvrtech77 Road Train Member
    15,502
    151,702
    Mar 20, 2010
    Have an issue with the heater only blowing truly hot air when i put temp knob up to 80 degrees. .other it blows cool air..what could be the issue?
  3. BCV
    BCV Light Load Member
    233
    436
    May 26, 2018
    Is your water temp normal or running cool ?
    Or, you talking bunk heater ?
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Got your taps wide open to heater core ?
  5. drvrtech77
    15,502
    151,702
    Mar 20, 2010
    Main system up front.
  6. drvrtech77
    15,502
    151,702
    Mar 20, 2010
    Haven't ever touched them...have had trk for going on yr and never had this issue before..
  7. drvrtech77
    15,502
    151,702
    Mar 20, 2010
    Water temp is normal..
  8. KentWorthinton
    KentWorthinton Bobtail Member
    Jan 24, 2019
    That hvac system has had actuator problems. Have a dealer run the test with ESA program. There could also be a software update.
    pushbroom and drvrtech77 Thank this.
  9. pushbroom
    pushbroom Road Train Member
    1,788
    7,397
    Sep 1, 2012
    Most likely a blend door actuator issue. There were a bunch of faulty actuators and also the possibly of a broken door.
    This does involve digging deeper into the dash so if you aren't experienced, a shop would likely diag it quicker and cheaper. Heater box.png
    Cat sdp, QUALITYTRUCK, SAR and 2 others Thank this.
  10. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    ESA would be best bet to narrow down issue. Above picture is great for reference........if you are working on a Freightliner M2 chassis.
  11. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Looks like a good reference to me for Paccar NGP/2.1M cabs. This is from HVAC service manual
    QUALITYTRUCK and pushbroom Thank this.
