Heater problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brookshire36, Feb 4, 2021.
  1. Brookshire36
    Brookshire36 Bobtail Member
    18
    Apr 28, 2020
    I have a 2002 ford sterling, the problem is my heater hoses are warm, the heater core is warm, replaced the thermostats, check all blend door and actuators, I did find the one that controls the temp from hot to cold was disconnected, connected it back up and as far as know of actuator is working fine, so blend door should be working, fired up truck this morning and still blowing cold air out of vents and bothe valves on motor are turned in on positions any help be appreciated thanks in advanced
  3. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    The inlet heater hose should be hot. The outlet hose should be cooler.
    If both are the same temp or close to each other. The core is plugged.
    The heater core works in the same manner as the radiator.
    Goodysnap Thanks this.
  4. Brookshire36
    18
    Apr 28, 2020
    The coming off water pump to heater core is warm, and the other that goes I guess outlet to the side of motor is also warm almost same temp
  5. snowwy
    20,590
    13,308
    Jul 6, 2009
    Plugged core.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    Probably should not share this but I was a teenager. 1958 Plymouth Savoy with that problem. The radiator had been leaking and I put stop leak in it. Radiator leak stopped but so did the heat. Went to the do it yourself car wash. Disconnected heater hoses from engine and used the pressure washer in hoses to core back and forth. Cured: I was a 17 year old genius and never had a problem with it after that.
    I would not try that unless you are at home. Cores today are likely not so strong.
    A good reason not to use stop leak.
    Goodysnap, Rideandrepair and cke Thank this.
  7. Rideandrepair
    17,424
    56,529
    Aug 8, 2015
    Did you replace hoses by chance? I got mine backwards on the bunk once. Had to swap then around on heater core to work. I don’t know about yours, but much to my surprise, mine supply’s cab heater core from block, returns to Waterpump. Always thought it circulated opposite. From Waterpump to heater core and returning to block. Seemed to make sense. But I was wrong.
    BoxCarKidd Thanks this.
  8. Brookshire36
    18
    Apr 28, 2020
    Nope haven't ever replaced hoses, just flushed heater core a lil junk came out bit not much them clear liquid and still no heat through vents
    Rideandrepair Thanks this.
  9. BoxCarKidd
    4,517
    6,576
    Aug 26, 2014
    I worked on a Sterling that had one of the duct doors broken off inside. Could not see it from the outside. It was a one piece plastic flap with a stub on each side. Maybe check those out. Mine was four hours plus of fun. Most all the dash out of it.
  10. Brookshire36
    18
    Apr 28, 2020
    I was thinking the same thing, even though actuators are working maybe door isn't, plus when I turn the setting from hot to cold or the other way there is no sound of anything think its the one that controls the temp, just gotta find where it is
