Heating problem after changing coolant
Discussion in 'Volvo Forum' started by Mohammed khan, Oct 4, 2018.
Run it with the cap off for 15 minutes or so after the thermostat opens.
KB3MMX Thanks this. -
Bleed the system.
Air pockets around the cylinders can cause hot spots and piston gauling.KB3MMX Thanks this. -
Sounds like you're still low on coolant.. there's a bubble in there somewhere..
This is what they recommend now a days.
https://www.amazon.ca/FJC-43610-Radiator-Coolant-Vacuum/dp/B00804HWOUKB3MMX Thanks this.
