Heavy Duty Trucks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jwill0105, Jun 13, 2018.
  1. Jwill0105
    Jwill0105 Bobtail Member
    10
    Good Morning All,
    I am looking for a Heavy Duty Sleeper cab to haul frac sand. Which brands/companies are reliable, good on gas not too costly in repairs, can take a beating out there on the oil fields, etc.
    What brands, what years should I bee looking at as well since I will be purchasing used. Should I purchase a warranty. If I were looking for a sleeper cab, 2010 - 2015, what is a price that is reasonable and what is considered good mileage?
    Thanks in advance
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    They dont burn gas, and we dont worry about MPG in the oilfield. If you have to ask these questions, you dont need to buy trucks. JMO.
  4. Jwill0105
    10
    You could have just refrained from responding my man. Either help me out or move on.
  5. kemosabi49
    10,977
    47,915
    Jan 13, 2013
    SW Arkansas
    He did help you out. Just didn't get the kind of answer you wanted.
  6. Jwill0105
    10
    Please! It was a general question, it was an honest mistake, I am new to this and Instead of being rude wont you enlighten. If you and him wanted to be smart you can move around. Looking for suggestions not people being smart.
  7. Ridgeline
    22,720
    123,337
    Well OP, the thing is that you are asking for an answer that just doesn't exist.
    Here is the questions that I need to ask to find out what you know.
    Are you a driver right now?
    And how long have you been a driver?
    I will start with that.
    OH and where are you at, put that in your profile.
    Tug Toy Thanks this.
  8. Jwill0105
    10
    Fair enough, I am not a driver. Looking to hire one soon. I have an "in" to start hauling sand. All I need to do is get a sand hauler and a sleeper cab and start the process per se. I know there's more behind it and I am looking into that.
    However, at this moment I am looking for a truck(a sleeper) and wanted to know the following and yes if the whole MPG mistake i made, please ignore or enlighten. I don't need smartasses if I made an honest mistake and being new to this, follow me. Ill need the truck for ND and TX. Focus is on TX right now.
    Thanks
  9. Ridgeline
    22,720
    123,337
    OK I try to discourage people getting into this business because it has a very high failure rate.
    Most of us have answered hundreds of times the same question and right now it seems that there is a lot of stupid (not your questions) being asked by people who see this as a money machine.
    BUT that said, you asked so here is my take.
    First you may need to stop worrying about the truck itself, there are thousands of trucks (literally) out there on the market, so finding a truck isn't hard, the buying process is. I will get into that a little bit later. BUT owning trucks require discipline on the financial end. Like the drivers ALWAYS get paid first, then the truck is taken care of after the driver. YOU build a maintenance column in you ledger and that comes right out after the driver, this can be based on hours or miles, but it has to accumulate. Then your insurance and fuel come out. If you can't make money with those components and your rate your charging, then something has to give and it should be your profit.
    Second you need to look at your business structure and throw away some of the per-concieved notions you have about this industry. The one thing that may be an issue is the need of an Authority, you may need it to operate in two or more states for hire. I know here if I want to run Michigan and Ohio, I have to have register my business in both plus use an interstate authority to operate between the two states.
    Third thing has to do with the second, you will have to have the right hiring policies, it isn't about just hiring someone with a cdl, but there are state/federal requirements that need to be met. For instance, every driver has to go through the same hiring process, has to have an annual disclosure of their driving record and so on.
    Fourth is important, once you get your business structured to function within the industry, then you need to talk to the insurance brokers. If you have to have an authority and you have say three trucks, your insurance cost could approach $50k a year. If you have crap drivers, which is most likely what you will get starting up, then that cost could increase. As an authority, you have to have the insurance in place before you can get it approved, then you will also have a annual audit on top of that.
    Fifth is how to purchase the truck. I will break this down with comments -
    1 - a truck is not a car. I get you understand this but it has to be said.
    2 - the truck brand is meaningless, Mack, Freightliner, KW, Pete, etc. ... no matter what others say are all the same.
    3 - the most important thing on a truck is the drive train - the engine, trans and rear end ratios ... oh and the tires. Each truck is spec'd for a specific job, for sand hauling (not oil field) I had running for a bit we spec'd on the heavy duty side, dual frames and geared for lower road speed. I haven't been out in the oil fields for a while but I would venture to say that going out there and actually seeing what they are using is the best way to get the spec close to what you need.
    4 - when you look at a used truck, you have the truck tested. It starts with a dyno and blowby test. A dyno will tell you how close the engine is to its specs - if it is less than 80%, pass on it. The blowby (which is only done under a load on a dyno) tells what condition the rings are in, the more blowby, the more worn the rings are. THEN if the truck passes, you get it inspected by a real mechanic and stress you want to know what is really wrong, worn and so on. At the same time, you put in time looking at the records from the owner, and having the dealer pull the records of the trucks warranted work. THIS is very important, you don't want a truck that is in the shop. YOU also have a complete ECM dump printed out, not a summary but one with every thing that is in the ECM, you compare the odometer and the records to see if there is any BS about it.
    5 - mileage? budget for about 3 mpg.
    Hope that helps.
    By the way, I have a reason to say there is a high failure rate in this industry, I have bought a few distressed companies because the owner saw dollar signs and thought they would make a 30% (some thought they would clear 60% return) only to find they couldn't handle the variables in the industry. I have two packages from a bank that they are offering to recover their assets on my desk, one owner ran it into the ground in less than a year, his drivers screwed him so badly that he started to pull his retirement out to pay the bills. So failure rate is high in this industry.
  10. Jwill0105
    10
    Rdigeline. Thank you for your well put response. This will definitely assist me moving forward. If I have any more questions I will reach out.
    Thanks again.
  11. RicoNC
    RicoNC Light Load Member
    92
    121
    Jan 31, 2015
    Raleigh/Clayton, NC
    More clear than this...impossible!
    rabbiporkchop Thanks this.
