Heavy Hauler Hub Seal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mr Bob, Feb 9, 2023.
  1. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    On heavy haulers I keep seeing hub seal failures. Is there a better seal for this application?
  3. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    You shouldn’t need a special seal for heavy haul. Any top brand correctly installed seal should not leak.
    Drive axle? Steer axle?
    What brands have you installed and how long did they last?
    If drive axle, the first thing I would be checking is the axle vent.
  4. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    I assume the issues are on the trailer? If you have a habit of turning hard with the trailer loaded heavy the side loading is hard on bearings and seal. Do your best to not fold it up hard. Also this will help your tires.
  5. Mr Bob
    269
    84
    Mar 17, 2015
    both tractors and trailers leak. im not driving so i dont know the exact conditions they go through. seems that all brands of seals dont last very long, not even a year.
  6. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    That would lead me to believe they aren’t being installed correctly.
    Oxbow Thanks this.
  7. Mr Bob
    269
    84
    Mar 17, 2015
    this happens only on the heavy trucks and trailers. installation is the same.
  8. Goodysnap
    3,778
    9,212
    Jul 12, 2017
    He’s trying to tell you that if the seals are not lasting then they are not being installed correctly, and I agree.
    No reason a correctly installed wheel seal shouldn’t at least outlive a set of brakes or longer. You need to find a new shop, or mechanic if your seals are only lasting a year or less.
    Jubal Early Times Thanks this.
  9. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    Or perhaps the spindle is dirty or has a groove. In any case that should be found and corrected at the time of install. So either the seal isn’t installed correctly or a spindle issue or the wheel bearings aren’t adjusted correctly. There is no special heavy haul wheel seal that I know of.
