Heavy shake/hop
Discussion in 'Trucks [ Eighteen Wheelers ]' started by crookedTRanspo, Mar 20, 2025.
  1. crookedTRanspo
    crookedTRanspo Bobtail Member
    23
    8
    Aug 5, 2019
    This post will be long and detailed
    Truck:
    2012 freightliner Coronado glider
    12.7 S60 Detroit 10 speed 3.36 Rears
    980,000 miles
    Front Steertek air ride suspension
    Rear airliner single leaf air suspension
    bought the truck 5 months ago/40,000 miles since purchase
    -previous owner mentioned driveshaft fell of truck and was replaced
    -month later power divider over heated and was replaced with a Reman DS404
    before I even hit the road I replaced the cab mounts, shocks, air bags and torsion bar plus a u joint at the trans yoke
    Plus 2 new continental steers
    New drums and shoes
    New steer shocks
    Front end was tight and in great shape
    The issue:
    Truck has a heavy shake/shudder/
    First starts around 40 mph
    Doesn’t matter which gear or rpm the truck hops every second or so
    43-60 no issue
    64-68mph it’s worse and worse the faster I go
    It’s like a wheel is literally hopping
    Very heavy shudder runs thru the whole truck
    You can feel it in the sleeper, driver seat, shifter, steering wheel, dash .. the whole truck
    It’s like 2-3 shudders a second
    the vibration is worse with loads under 10k lbs and with 44k loads barely there
    Tried 2 different trailers and no difference in vibration
    Barely noticeable when bobtail
    Clutch down and truck out of gear changes nothing so that rules out motor, clutch, flywheel
    it’s literally shaking this truck apart
    everything replaced so far
    Driveshaft with slip yoke developed play so had a new one built from scratch
    All drive angles are under 2.3 degrees
    Ride Height at 2-5/8 inches
    Alignment at truck rebuilder shop and he also checked pinion angles and ride height and said that was good
    Also checked front end and everything was tight
    no difference in shudder
    transferred 8 wheels and tires from the truck I parked when I bought this one (I use centering bolts when I did this so wheels are centered)
    No difference
    New Eaton DSP 3.36 power divider after the
    The Wheller reman front yoke had developed play and started to leak (not a fan of wheeler remans)
    New axle shafts as well since the ones in the truck were Chinese aftermarket
    New rear diff fluid(fluid was old but not burnt and no metal shaving)
    no difference
    had my dad drive his car around me on the highway and saw the drives wobbling
    And confirmed when we put the truck on jack stands and ran it at 45mph
    -4 new Conmet preset plus hub assemblies
    -4 new premium balanced drums and shoes
    no difference
    interaxle shaft slip yoke developed play so had a new one built from scratch
    Front two shafts were also checked and had carrier bearing replaced
    -checked pinion angles again and all within spec
    no difference
    10 new Toyo tires
    2 new steer Alcoa wheels
    1 rear wheel was iffy
    ALL balanced and centered with centered bolts
    4 new Monroe magnum shocks
    -alignment same day this time at Purcell and was good
    no difference
    new bushings and rebuilt Fontaine fifth wheel
    New torque arms
    no difference
    I’ve pretty run out of ideas of what it could be
    I’ve replaced everything that rotates in the drive portion of the truck
    All the suspension bushing look great and are tight
    I can’t remember the measurements from the top of my head but the frame of this POS truck doesn’t sit parallel to tfw ground
    The front of the frame is 2.5 inches lower than the back
    The front air ride is maxed out and the rear drive air bag sits 1 inch taller than the front drive air bag
    I’ll try to sort that issue next but with pinion angles being under 3 degrees I don’t know if this would cause any issue
    any and all insight will be greatly appreciated
    Bean Jr. Thanks this.
  3. crookedTRanspo
    23
    8
    Aug 5, 2019
    Literally the more I spend and the more things I replace I swear the truck gets worse.
    I am putting in a 13 speed in the next week or so and will take driveshafts in to get shortened and I’ll have them recheck them but shudder is to heavy and consistent and slow to be shaft issue
  4. crookedTRanspo
    23
    8
    Aug 5, 2019
    Also, NOTHING is heating up of wearing unevenly which is the most frustrating part
  5. JB7
    JB7 Road Train Member
    1,018
    1,804
    Dec 13, 2022
    Laurel, MD
    1 - timing of the driveshafts. Was the new driveshaft balanced?
    2 - engine harmonic balancer. I read that you had clutch in and trans out of gear.
    3 - engine and transmission mounts
    Was the truck this way when you first bought it or did it start sometime after?
  6. Deezl Smoke
    Deezl Smoke Medium Load Member
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    and
    So now your inter axle drive line is is at a steeper angle than spec.
    I'd want to know what front axle is under that air ride? I suspect your front axle may have too much drop.
  7. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    Why not take it to a good driveline shop (a shop with a dyno could be useful as well) instead of throwing endless amounts of money at it or asking random strangers that cannot see it in person to "diagnose" it?
    JB7 Thanks this.
  8. 201
    201 Road Train Member
    12,782
    26,304
    Apr 16, 2014
    high plains colorado
    Such a shame people are spending so much money on these problems, being the skeptical type, these parts replaced could be junk out of the box. In a situation like this, they( foreign parts makers) know, it's not like it's a clear cut deal what's wrong, any number of things cause this, so they sell you inferior parts, they get their money, and it does nothing, or in this case, gets worse. If only trucks could talk, who knows what this thing has been through, and a million miles, it's clear, the truck has had it's useful life. It was so much easier with the old Transtars, they were made to last. Freightliner doesn't sell new trucks by keeping the old ones going. That carries over to the general attitude for all products today. Sounds like you have $20 grand in a $10 grand truck, I hope you get it figured out.
  9. Deezl Smoke
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    What people "need" to understand, is that each of us is an individual. It's important that not everyone thinks or does the same as everyone else.
    Everyone should take a step back and look at their own self. Many that condemn spending money on an older freightliner, spend 10 times that on a landscape for their house. It's just as stupid, or,....just as smart. It's all about individual views on life.
    If anyone wants to talk about "controversial",.......just have a look at Wicked Intent. That guy has bigger brass than this whole board combined. I totally respect what he does and has done to his...... Freightliner.
    nikmirbre and 201 Thank this.
  10. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    For hops and shakes, I generally find any time the steering wheel shimmies back and forth, it is a steer tire problem. If you feel the whole truck shake or bounce and feel it in the seat, it is generally a drive tire. The frequency is not so fast to the point you can almost count the number of bounces. This is also consistent with a tire. Anything else simply spins too fast and becomes more of a hum or buzz. I take the truck, like you said, and put it up on jack stands again. Run it around 30mph or so and watch the drive tires to see if they are running out of round. Pick all the stones out first. If you run the truck at highway speed on stands, sometimes you cannot see the problem because the wheels are now spinning too fast for your eye to catch. The tire will be going up and down as it is rotating. Tires can be mis-mounted and wheels can be machined too big and not properly center on hubs even when they are new or have been swapped from other trucks. I find centering nuts do not always help, especially when the tire is not mounted true on the wheel in the first place. I hold a tire crayon very close to the tread of the tire and only the high spot of the tire makes contact with the crayon. Then adjust as needed. I hope this helps, good luck!
