Hello, How do you move an engine to storage?
Discussion in 'Ask An Owner Operator' started by Dok2304, Dec 21, 2024.
  1. Dok2304
    Dok2304 Light Load Member
    185
    49
    Sep 19, 2013
    I’ve purchased a damaged semi, with bad frame, I’m trying to salvage the engine and transmission. The mechanic that remove the engine, said that differentials, I mean the rears are not worth it. He also mentioned they are 2 speed rears, which means they have 2 ratio.
    Anyway , he can’t store those there, and I need an engine, but mine it’s still ticking, and I think I can get another year or who knows maybe 2.
    How do you move an engine and transmission to a storage facility. Storage facility don’t have any equipment on premises to remove and move heavy objects like, I think a 3,000LB engine. These are heavy stuff.
  3. Long FLD
    Long FLD Road Train Member
    12,882
    53,938
    Mar 4, 2015
    Hire someone that has the equipment to do the job.
  4. Stringb8n
    Stringb8n Road Train Member
    1,704
    2,230
    Sep 27, 2015
    ^^^ what Long FLD said. I will add that if you really want just a plain jane storage facility, you could have the stuff hauled to you and then unload it with a forklift you rent yourself and place it into the storage building.
  5. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Find two pallets that have at least a 3k lbs capacity each, strap the engine on one, the transmission on the other one.
    Rent a box truck with E-track, with a high capacity lift gate, and use a high capacity pallet jack to position it where you need it to be.
  6. Dok2304
    185
    49
    Sep 19, 2013
    Ha ha, . I wonder what is the lift gate capacity weight? I see on Detroit specs, an Detroit 60 engine say it’s 2550 LB dry, whatever that means.
    Rent a Uhaul box truck with E track., I’ll have to call them and see if they have any
    77fib77 Thanks this.
  7. Dok2304
    185
    49
    Sep 19, 2013
    Actually I need a truck with lift gate , and none have one to rent.
  8. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    U-Haul won’t have what you need…Probably only Penske or Ryder….
    You could see if there is any one local that does local carriage….might be cheaper than renting equipment
  9. Dok2304
    185
    49
    Sep 19, 2013
    About the pallets , I think I’ll have to build one myself.
  10. boneebone
    2,297
    2,372
    Mar 13, 2009
    U-Line has 5,500 lbs capacity wooden pallets for $89 each.
  11. boneebone
    2,297
    2,372
    Mar 13, 2009
    Try Enterprise Truck Rental
    Dino soar, TX2Day and Dok2304 Thank this.
