Help 02 Freightliner classic xl starting issues
Discussion in 'Freightliner Forum' started by woodsplitter, Sep 20, 2022.
  1. woodsplitter
    woodsplitter Bobtail Member
    16
    Aug 30, 2012
    all over the US
    I’ve got a n14 and it takes about 40 seconds for it to crank every time even after it’s warm. After it starts it runs fine. I’ve inspected the check valve and I don’t think it’s that. Any advice is appreciated. Thanks In advance
  3. 062
    062 Road Train Member
    5,459
    18,038
    Oct 20, 2013
    I’d check fuel pressure while cranking. It takes a little over 20psi before the injectors fire.
  4. woodsplitter
    16
    Aug 30, 2012
    all over the US
    Ok thank you. How do I check the fuel pressure??
  5. 062
    5,459
    18,038
    Oct 20, 2013
    Easiest way would be to find someone with a gauge that has the compucheck fitting.
    The other is to put a pressure gauge in line after the fuel pump.
    woodsplitter and QUALITYTRUCK Thank this.
  6. uncleal13
    uncleal13 Road Train Member
    3,549
    5,630
    Apr 9, 2009
    Humboldt, Sk
    Did you change the fuel filter recently?
    I have seen Baldwin filters cause this. The o-ring is too thin allowing just a small amount of air in causing the truck to lose prime when off, but once running it is overcome.
    LoneRanger and QUALITYTRUCK Thank this.
  7. woodsplitter
    16
    Aug 30, 2012
    all over the US
    No I haven’t but I will definitely check this out thanks
  8. woodsplitter
    16
    Aug 30, 2012
    all over the US
    Ok thanks for the help. This is where I will start.
  • Draft saved Draft deleted
