Help. 2004 Pete 379 Will not start. Not turning over
Discussion in 'Peterbilt Forum' started by walshie38, Mar 10, 2012.
  1. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    Id also be concerned that your seeing 16v . That's a fire waiting to happen.
  3. walshie38
    walshie38 Bobtail Member
    14
    Mar 10, 2012
    Great i am going to look into all these options ..
    About the 16v . I will check that i am correct on that as both trucks say 16
    Thank you
  4. walshie38
    14
    Mar 10, 2012
    Thank you for all the help.
    Just to let you know it was a loose bolt on the starter.. :biggrin_25512:
    The Challenger Thanks this.
  5. Graglor
    Graglor Light Load Member
    62
    15
    Aug 17, 2011
    Langley, bc.
    What the above said!!!!! Loose starter connections. Might want to put a jump cable on the ground terminal to the ground on the batteries too, just to eliminate the hound cable which is common too.
