help. a/c on, engine fan wont shut off
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Nov 4, 2010.
  1. Smalltruck
    Smalltruck Light Load Member
    141
    68
    Jul 3, 2010
    Elko, MN
    Depends on what that sensor was for, a guess is thats the high pressure sensor. So it is usually a Normally Closed switch that opens at a certain pressure to complete the circuit. The paper clip closed the circuit so the ECM read the system as having normal pressure.
    NC switches are ones that complete the circuit until pressure is applied, then the switch opens and no power goes through. NO (Normally Open) interrupt the circuit until pressure is applied. then the circuit is closed and power goes through the switch.
    An example of this a brake light switch. These are usually NO until you step on the pedal and air pressure closes the switch and the brake lights come on.
    Hanadarko had a problem with the parking brake switch on his DD-60. That switch is a NC switch until you push the yellow knob in and release the brakes. Pressure gets applied to that circuit and the switch gets opened.
    You can test these by using a jumper wire or disconnecting them to replicate what the switch is supposed to do and not do, IE either on or off
  3. Jeet
    Jeet Bobtail Member
    24
    4
    Jul 17, 2010
    does your truck have a APADS to control your ac. These units do go bad, and cause the engine fan to stay on. Just a thought, you might wanna take a look at that.
  4. droy
    droy Heavy Load Member
    828
    160
    Jun 11, 2008
    Iowa, LA
    I JUST went through the same thing on my '04 W900- Only after second sensor, SM at South LA Kenworth informed me the problem was not sensor, but the harness (near the AC drier, on radiator). I cleaned all the connections, problem solved, for a while. Now and again, I have to unplug/plug to gain contact. Stop at KW is in tomorrows plans.
  5. Heavyd
    Heavyd Road Train Member
    7,831
    6,282
    Feb 4, 2009
    Sometimes we see the actual pins in the connector at the high pressure switch are spread open. The paper clip trick can sometimes make it worse. The paper clip can be thicker than the terminal that is suppose to go in there and bend the little terminals too wide. This will cause goofy operations too.
  6. tclargecar
    tclargecar Bobtail Member
    7
    4
    Jan 16, 2014
    Morristown tn
    I have same problem. Where is this sensor?
  7. rollin coal
    rollin coal Road Train Member
    13,735
    28,324
    Mar 29, 2008
    TN
    It's on the left front top corner of where a/c lines go into the condenser. There are two sensors plugged into the line. The red one closest to the front end of the truck is where mine's at. I assume they're all pretty much the same on any KW. I'll post some pics later when I get some time. It might be the sensor is bad. Or it could even be poor connection from the harness being bad. Me jumpering mine with a paperclip to turn the fan off messed up the harness so I ended up having to replace it later when the fan started coming on again. It's a short jumper harness that's not very long just plugs into the high press switch on one end and main harness on the other end. Not very expensive, neither the switch nor the harness.
  8. rollin coal
    13,735
    28,324
    Mar 29, 2008
    TN
    Pic taken from standing on the steer tire looking down at the left front corner of radiator/charged air cooler area. Where the a/c lines go into the condenser that's where the high pressure switch is. In the pic there are 2 plugs it's the reddish/brown one on top. Closest to the grille.
    W903B and 04 LowMax Thank this.
  9. Lowboy456
    Lowboy456 Medium Load Member
    301
    147
    Mar 14, 2017
    Sometimes plugs get worn out with vibration from the engine and no matter what you do you just have to get new plugs.
    I had plugs go bad on a 96 Peterbilt 357 Dump Truck. Both hi and low switches on that truck were sent a ground from the control panel.
    With AC switched to on that system sends a ground strait to the low side switch 1st, then through the high side switch and then to pin 85 in the AC relay located in the fuse box.
    On that AC relay pins 30 and 86 are hot with the key on but no ground to pull in the relay is found until it passes through both hi and low switches.
    And you know the dealer ain't gonna put 5 inches of wire on a ready to solder plug, you have to put the entire plug together, crimp on the new pins, install them into the connector, shove in the little water tight seals, snap on the cap, then solder and heat shrink the wires that you had to buy elsewhere.
    Preferably with glue lined heat shrink.
  10. ihc4b
    ihc4b Light Load Member
    52
    17
    Dec 29, 2021
    I am having this same problem on my 2006 western star with a c15 accert. I will go inspect my plug to the sensor. I had the system redone, new compressor and drier. New pressure switch. unplugging the compressor is the only way I have turned off the ac compressor. Engine fan is stuck on. Using jumper wire I verified, fan selinoid is good. Unplugged the pressure switch no change. Plugged the old switch in, but not screwed onto the refrigerant pipe. No change. All ac switches dash and sleeper and defrost turned off. Wanted to try the paperclip truck, but this sensor has 4 connections in the plug. Not sure what all those connections do, and did not want to short out anything. Any suggestions? I do believe the engine fan and ac compressor problem is related
