Help backing flatbed
Discussion in 'Experienced Truckers' Advice' started by Western1, Apr 3, 2026.
  1. Western1
    Western1 Bobtail Member
    7
    18
    Apr 3, 2026
    Hello, I’m new to trucking and a recent graduate from CDL school. I am currently at Western Express in flatbed division and I am really struggling with backing. I didn’t have any problems with backing in school but we were using vans and manual transmissions. My trainer is pretty much useless in helping me as he just keeps getting excited and then I can’t focus. Any tips or tricks appreciated because the way they taught me to do a 90 in school is not really working for this.
    blairandgretchen Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    77,995
    185,889
    Aug 28, 2011
    Henderson, NV & Orient
    Is it a spread axle trailer?
  4. Western1
    7
    18
    Apr 3, 2026
    Yes
  5. Chinatown
    77,995
    185,889
    Aug 28, 2011
    Sometimes you have to dump the air on one of the axles.
    It's been a long time since I pulled flatbeds and that was also with Western Express.
    I alerted three flatbed drivers that can probably explain it more clearly than me.
    Wargames and blairandgretchen Thank this.
  6. Western1
    7
    18
    Apr 3, 2026
    Thank you. Nobody has told me anything about dumping the air. Tbh I’ve learned more from google than my trainer.
  7. Chinatown
    77,995
    185,889
    Aug 28, 2011
    One of the drivers I alerted will help you as soon as they see the alert.
    FullMetalJacket Thanks this.
  8. Ddh77777
    Ddh77777 Light Load Member
    221
    332
    May 28, 2025
    Practice more with setting up.
    If you're trying to do a 45 degree into a parking space in a row at a truck stop. pull up until you're a little before halfway up the space two spaces front of the one you want to park in. Turn your wheel all the way right until both shoes of your landing gear are visible in your passenger side convex. Little bit too far is better than not far enough. Turn your wheel left and pull forward until you're roughly facing straight down the aisle/your cab is 90 degrees from the trucks parked in the row. Straighten your wheels so the truck is moving straight backwards and you're just steering the trailer. Wait much longer to get underneath it than you did with the van, because it won't change direction nearly as much as a tandem does.
    Practice in double empties and don't try to wrestle it into the space if it isn't gonna go. If it didn't, make a note of your setup at the points I described above, and adjust something. Start from further up or back, cut to the right longer or not as long, get underneath it sooner or later, and see how the trailer responds.
  9. Ddh77777
    221
    332
    May 28, 2025
    I know that seems tedious but it's how you develop that sense of what you need to do to get it to go where you want.
    JolliRoger Thanks this.
  10. Concorde
    Concorde Road Train Member
    5,510
    19,624
    Jun 29, 2016
    West Melbourne Florida
    Ask for a new trainer..
