Help! buzzer!
Discussion in 'Volvo Forum' started by supertruck#1, Jun 27, 2015.
  1. supertruck#1
    supertruck#1 Bobtail Member
    39
    14
    Nov 17, 2014
    ok had my 2006 volvo in shop for parking break light constantly on and horrid buzzer!
    they replaced the dash cluster... thought problem fixed but 100 miles down road its back! they say to replace the parking break pressure sensor and i picked one up from parts house.... i read in a previous post its on the firewall under hood.......looking under my hood i see 6 sensors on firewall that all look the same! which do i replace.... any place online that has a diagram?? please please help can't take this buzzer much longer and after the $3000 dash cluster i would like to replace this sensor myself just need to know which one to pull.... if it was a Pete i would know what to do..... attached park given below IMG_5137.JPG
  3. FuzzFace2
    FuzzFace2 Medium Load Member
    417
    137
    Jul 27, 2014
    Angier, N.C.
    What would happen if you disconnected each sensors 1 at a time to see what happens you may find it turns off and know that is the one?
    Dave ----
    blairandgretchen Thanks this.
  4. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    If you look closely at the harness attach to the pressure sensors and pressure switch ( LH under the dash just in front of the clutch pedal inside of the cab) there is a tag on each harness telling you their function.
    Sorry i don't have the diagram requested.
    Hope this can help.
    Ben
  5. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    the parking brake sensor has a different connector from every other sensor it only goes in one place its about half way on the manifold on most models but you have to be careful when replacing this sensor because the way it plugs into the manifold is with a quickconnect fitting there is very little room to work and if you break the manifold or fitting then youre screwed just check connectors it should be next to the orange line and there is an etching on the manifold saying pbs you can't mix it up only one connector fits
    dorlia2 and QUALITYTRUCK Thank this.
