Help !!!! Cab leveling issues !!!!
Discussion in 'Ask An Owner Operator' started by Browntyreese, Sep 28, 2020.
  1. Browntyreese
    Browntyreese Bobtail Member
    My 2011 International prostar is having leveling issues. It jumps at random and especially when I am parked. I replaced the valve and still having the issues. It is to the point to where it is damaging my lower cab at the rear. The airbags dont have leaks. Can someone please help ???
  3. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    To make really long storey short. I had kinda the same issue and the only short term cure was to raise the susppension all the way up while I was sleeping.
    But my lifting is no where near as extreme as yours.
  4. Dino soar
    Dino soar Road Train Member
    4,803
    26,920
    Dec 8, 2017
    How do you mean it jumps?
    You mean like a lowrider the cars with the Hydraulics that bounce up and down?
  5. Old Man
    Old Man Road Train Member
    4,597
    13,470
    Apr 3, 2009
    Oklahoma City, OK
    Wore out shocks
    Browntyreese Thanks this.
  6. DaytonTD
    DaytonTD Light Load Member
    164
    186
    Jul 14, 2019
    Edmonton, Alberta
    If you have the correct leveling valve and correct ride height position when you put the new one in then it is probably the shocks
  7. Roger.B1240
    Roger.B1240 Bobtail Member
    44
    66
    Jun 29, 2020
    Dallas Tx
    The symptom looks like both front airbags on the front suspension has bad valves on the air supply. There was a recall on that splitter type valve many years ago for the IH Prostar class 8 hd truck for a defect.
    prostar.JPG The suspension has no shock absorbers it uses air bags to lift and stabilize the tractor, the fault is caused by a loss in air pressure.
  8. Browntyreese
  9. Browntyreese
    Yes like a car with hydraulics.
