help cascadia 126 have Noise when accelerating
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TJLM, Sep 15, 2023.
  1. TJLM
    TJLM Bobtail Member
    Sep 15, 2023
    My 2019 cascadia 126 dd15 have Noise when accelerating,There was noise when I was driving at a speed of over 35 mph, and the noise became louder when accelerating. The truck drove normally, there was no engine light, I thought it was the turbo at first, but there's nothing wrong with the turbo and The mechanic checked and said it might be a problem with the transmission . I need to pay a $1,000 fee to check but I don't think it's the transmission . Does anyone know what the cause is? Thank! There is a video below for reference. https://youtube.com/shorts/q4HNiQ_634A?feature=shared
  3. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,478
    Mar 18, 2021
    St Malo mb
    Being a 2019 it must be close to a transmission oil change interval of 500 k if it hasn’t been done I’d probably start there and see condition of old oil .. cascadias are bad for oil cooler lines rubbing through and slowly seep oil at first causing a wired humming noise like a turbo leak. I know my boss changed two transmissions due to that problem. Now he’s changed lines on a few others as preventive maintenance due to rubbing .
    TJLM Thanks this.
  4. TJLM
    TJLM Bobtail Member
    Sep 15, 2023
    Thank you,t
    The oil is good and was changed a few months ago. I just checked the driveshaft and it looks like there is a problem where the transmission and the yoke are connected. I do have to check the transmission . Thank you very much for your help. I uploaded another video:
    Magoo1968 Thanks this.
