HELP: Cascadia check engine lights
Discussion in 'Freightliner Forum' started by Rich_Trucking, Mar 25, 2013.
  1. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Oh, you told them it could be a sensor, well there's only about 2 or 3 sensors on a Cascadia,right? Shoulda just swapped 'em out and sent you down the road.
  3. robinrene
    robinrene Light Load Member
    81
    59
    Jun 3, 2012
    Gypsy, USA
    To find your codes (if you have a problem in the future)
    theres a rubber reset button on the dash by the air guages.
    Keep cycling thru until you see the codes in the screen where you see your mileage etc
    it'll have a few different screens like
    ECU 128
    pid 411
    fault 1
    fail 13
    and no it wont work the same with the + button on the wheel
    Bella77 Thanks this.
  4. johnnie g
    johnnie g Bobtail Member
    Did this fix your problem...
  5. truckerdadyo
    truckerdadyo Bobtail Member
    Oct 2, 2012
    Martinsville, IN
    i have 2013 cascadia dd15 getting check engine light with ecu 0 and sfu 49 flashing any ideas what this is?
  6. moosc
    moosc Road Train Member
    3,284
    1,172
    Mar 5, 2009
    Lincolnton NC
    My 2014 DD15 Evo has flash codes still.
    Sent from my Nexus 4 using Xparent Cyan Tapatalk 2
  7. robinrene
    81
    59
    Jun 3, 2012
    Gypsy, USA
    I actually had mine in the shop twice now, if the codes are not active, the KC Freightliner by 435 doesnt give a ####.
  8. GPappy
    GPappy Bobtail Member
    EEC 061 SPN003720
    DPF Ash 15
  9. GPappy
  10. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    At least it's throwing a code. When you have problems and there is no code to tell them what's wrong then you are in trouble.
  11. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
