HELP: Cascadia check engine lights
Discussion in 'Freightliner Forum' started by Rich_Trucking, Mar 25, 2013.
  1. SLCTrucker
    SLCTrucker Medium Load Member
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    What year is the truck?
    Is it the check engine light or MIL light coming on?
    If a light comes on there is a reason, the code should be stored & should show as a inactive code unless you have a bad ECM
    If it will only run good for 45 minutes before throwing a code maybe you need Detroit to hook the computer up & drive until the light comes on.
  3. atampro
    atampro Bobtail Member
    13
    May 26, 2018
    Fort Pierce, FL
    Diag 05 Fail 07 spn 523318 sys 58 fault 05 fail 02 spn 3364 fault 04 fail 18 spn 4364 eec 61 fail 05 spn 520919
    My 2012 Freightliner Cascadia is throwing all these codes. Won’t do a regen and had def system cleaned a couple months ago a doseelr sensor replaced
  4. Osuna64
    Osuna64 Bobtail Member
    I have a 2009 freightliner cascadia have soent way too much money taken it to the dealer and still haa rhe problem . When the truck is going up hills the check engine ans the key light turn on so basically i have to stop the engine check the oil water levels and turn it back on ans the lights go away ans i start the drive again once i go uphill the same thing occurs .. can somepne explain me what else it can be i am reallt dont know qhat to fo with this truck since they cant fix the issue. TIA
  5. 25(2)+2
    18,762
    46,074
    Sep 18, 2006
    the road less travelled
    Which engine do you have in the 2009 Cascadia?
  6. Treed6129
    Treed6129 Bobtail Member
    6
    -80(flashing) hours service and solid engine light. Whats that mean
  7. Quezote
    Quezote Bobtail Member
    I have a 2014 freightliner Cascadia The coda came up with SPN 102 FM I 18 is that a booster sensor
  8. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Intake Manifold Pressure Lower than expected.
    Look for a blocked/ plugged radiator (winter front) , boost leaking, or could be a boost sensor it’s self. Past that it’ll take a dealer or shop to finish the diagnostic.
