Help changing Pete 379 fuel lines
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cajuncowboy654, Feb 27, 2024.
  1. Cajuncowboy654
    Cajuncowboy654 Light Load Member
    138
    34
    Jun 4, 2019
    Any tips on getting the fuel lines out and new back in on a Pete 379?
    They are wrapped and tied up in the frame rail with everything else, looks like a PITA.
    Do I just apart cutting tie wraps and unbolting the metal straps or is there a trick to it?
  3. lester
    2,958
    8,091
    Jan 2, 2012
    NW, Iowa
    no real trick. Have yo get everything loose enough to pull em out and get new ones in. Cover the ends of the new hose before pushing it thru to keep dirt out of the lines.
    keep everything the same length and routed the same or you'll have trouble keeping tanks equal
    Diesel Dave Thanks this.
  4. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    Cut the tie straps and loosen up the P clamps tie some wire on fitting on the end of the old lines on the opposite end you pulling from or connect the new fuel line to the old line then pull it through tape the ends like @lester said it just takes time and patience but it’s doable
  5. 50WT
    50WT Road Train Member
    3,152
    29,140
    Dec 26, 2015
    What everyone else said , also if you can pressure wash the best you can it'll make it a lot easier. And even after tape on the ends I'd blow the new lines out with compressed air before installing.
    Last Call Thanks this.
