Help Deciding on First Job (Flatbed or Dry Van)?
Discussion in 'Experienced Truckers' Advice' started by jaginFL, Mar 6, 2025.
Which?
  1. Flatbed
  2. Dry Van
Results are only viewable after voting.
  1. jaginFL
    jaginFL Bobtail Member
    26
    45
    Dec 25, 2024
    Hi,
    I am a new CDL driver. I made a previous thread about being approved to attend orientation at Prime Inc. and Knight Transportation. Knight orientation is 40 minutes away from my home whereas Prime would require air travel.
    I was feeling better about going with Knight and doing dry van. However, I am having second thoughts and thinking that maybe the TNT training at Prime Inc, along with doing flatbed would be better for me [long term]…
    So, for a new CDL with no tie downs at home and an open schedule, what do you guys think?
    Knight—Dry Van
    Prime Inc.—Flatbed
    Thanks!
  3. JonJon78
    JonJon78 Road Train Member
    7,241
    43,025
    Jul 1, 2018
    Start out doing flatbed. If down the line you decide to switch to dryvan you won't need training. If you start with van and eventually you want to switch over to flatbed most companies will make go back out with a trainer.
    jaginFL Thanks this.
  4. Diesel Dave
    9,664
    32,741
    Jan 20, 2010
    Hesperia, Ca.
    I started out flatbed and driving at the same time back in 1980, 101 style(those days are long gone). Did door slamming for a couple and went back to Skateboarding. Never looked back.
  5. lual
    lual Road Train Member
    5,323
    9,712
    Oct 22, 2020
    SW Georgia
    Here's an option you might consider....
    With Knight -- you could start out your first year as a driver doing dry van (which will make your first year MUCH, MUCH easier)....then later...you could switch over to flatbed duty (Knight has both) -- & thus...without changing employers.
    Work smarter -- NOT harder. :confused:
    -- L
    Numb and jaginFL Thank this.
  6. lual
    5,323
    9,712
    Oct 22, 2020
    SW Georgia
    Before doing flatbed at Prime -- read posts 12 & 13 in the following Forum thread -- then think about it:
    Considering flat bedding....
    -- L
  7. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Definitely Knight. You can leave the truck on their property, which is important for security and repairs. You’ll have enough responsibilities on your plate, with just learning to drive the truck, without learning flatbeds. You should have almost unlimited loads to haul with them. Keep it simple.
    After you get some years experience and if you’re still wondering about flatbed, it doesn’t get any better than Maverick. Their loads are the cherries every other flatbed company would like to pick. They do not haul junk loads, which means you’re not killing yourself. Pristine equipment. Great pay. Great benefits. However, they have very little to do with FL, because there’s no money in FL loads.
    lual and jaginFL Thank this.
  8. plant
    plant Heavy Load Member
    862
    806
    Sep 21, 2012
    Los Angeles, CA
    I alluded to this in your other thread, but if you are pre-hired for Knight, you should be in theory also pre-hired for Swift, and Swift has a flatbed division.
    And I would absolutely recommend starting with flatbed (or tanker with Prime) instead of Dry Van or reefer. It is more physical work, but it is a much more pleasant experience, with better treatment and better working hours.
  9. A Bug
    A Bug Heavy Load Member
    947
    1,955
    Mar 15, 2014
    Sevierville TN
    After six years of dryvan work I took a job with Fraley and Schilling. They did not require me to go out with a trainer so I was learning the ways of flatbed securement on my own pretty much and it was like learning to drive a truck all over again. Not sure I could have done it had I started out trucking like that.
  10. RollinChaos
    RollinChaos Light Load Member
    168
    286
    Oct 6, 2024
    North Carolina
    Some may say I am lazy, that's OK we all have opinions. I chose dry van because I didn't want to deal with tarps that can weigh in around 100 pounds.
    If you are thinking flat bed have a look at https://www.howardtransportation.com/index.cfm they have a very through and well paid training program. I passed based on my aversion to tarps and the time in orientation being about 9 weeks.
