Help determine 3030 push rod length
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cmulli56, Mar 31, 2026.
  1. cmulli56
    cmulli56 Bobtail Member
    7
    Sep 22, 2019
    We are rebuilding the suspension on an old east dump trailer. All 4 chambers have different rod lengths, and none of them stroke the same either. How do I know what to cut the new ones at? Normally I have old chambers to reference or a tape measure but I’ve never had a trailer this out of whack before. Thanks in advance!
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,560
    6,646
    Aug 26, 2014
    Are you running automatic slacks?
  4. BoxCarKidd
    4,560
    6,646
    Aug 26, 2014
  5. JB7
    JB7 Road Train Member
    1,047
    1,855
    Dec 13, 2022
    Laurel, MD
    brake-school.com/bsrepo/video/VID-2020-013/properly_cut_ pushrod_clevis.mp4
  6. cmulli56
    7
    Sep 22, 2019
    Yes
  7. OLDSKOOLERnWV
    19,235
    291,046
    Are they by chance mix matched long stroke and short stroke chambers….?
    BoxCarKidd Thanks this.
  8. cmulli56
    7
    Sep 22, 2019
    No they’re all 2.5”. That is one I checked. It’s a trailer we only use a couple times a month. Finally needed rebuild, prior owner was let’s say shade tree on steroids. But now that I’ve got everything changed over I found this brake length issue and am having a hard time wrapping my head around how it’s to be set. It’s a Hendrickson ht300 suspension. Hendrickson is unsure what the factory push rod length is, so is East MFG
    OLDSKOOLERnWV Thanks this.
  9. wichris
    wichris Road Train Member
    4,522
    9,328
    Jan 17, 2011
    Proper length is the slack is 90 degrees to the rod when brakes are applied.
    JB7 Thanks this.
  10. OLDSKOOLERnWV
    19,235
    291,046
    When the brakes are set or applied, are the slack adjusters at different angles? All should be at a 90 degree angle to the push rod with brakes applied.
  11. cmulli56
    7
    Sep 22, 2019
    Yes. 2 are at 90 degree but the orange indicator on rod is showing. 1 is well over 90 and the orange indicator is out, 1 is 65 degrees and orange indicator is showing
