Help!!! Does this charge air cooler can be saved?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Nando85, Aug 11, 2017.
  1. Nando85
    Nando85 Bobtail Member
    43
    6
    Aug 9, 2017
    Can I really save this cac or from looks needs replacement? My truck running 220 I wonder if this was the problem didn't know if to go radiator or cac?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    You talking bout the fins? Just comb them straight if it ain't leaking. Blow the rad and cac out with an air hose not water. Water will turn the debri to mud and when it dries it will be like concrete.
    Nando85 Thanks this.
  4. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Looks fine to me. You can look for leaks at the boots on the CAC. I'd look at the radiator/thermostat and water pump.
  5. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Yes for leaks on the air charge piping. Just idle up to around 1500 rpm and squirt the boots and all conections with soapy water and look for bubbles. Any bubbles and you have found a leak.
    fargonaz Thanks this.
  6. fargonaz
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Don't forget to check your fan make sure it's operating when it should and that the fan clutch is locking up(no squealing.)
    Nando85 and Superhauler Thank this.
  7. Nando85
    43
    6
    Aug 9, 2017
    Ok definitely try the blow cac and radiator, thermostats? 96 degree plus heavy hills 220-225 ,iddle 210,what would you guys do next
  8. Nando85
    43
    6
    Aug 9, 2017
    One thing I noticed iddle 210 fan should kick in bring down right not happening
  9. fargonaz
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Those sound like normal temperatures for the situations you described. As long as the fan is coming on and it doesn't rise much above 225. On a hot day with the A/C running I'll be constantly kicking the fan on and off(210 on my cummins.)
  10. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    What was posted then look at air filter to see if plugged. And turbo take induction pipe off and inspect turbo fins for damage or marks in the housing. All the free stuff first before you start throwing $$$ at it.
  11. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    What part of country you in? What are the outside temps?
