HELP Eaton fuller 8LL/9LL transmissions
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Wncdb, Mar 5, 2020.
  1. Wncdb
    Wncdb Bobtail Member
    4
    Mar 5, 2020
    North Carolina
    Eaton fuller 9LL or 8LL problem. I bought my truck 2 or 3 months ago and everything was working as it should. All of a sudden I get into my truck one day and the deep reduction stopped working. As of right now I can flip the switch foward and you can hear air being supplied down to the transmission, but it does not make that final locking noise and does not engage. I do not use the deep reduction a lot, and when I do it’s always from a stop “sitting still” and usually just for Low gear. Any help would be greatly appreciated!
    Thanks
  3. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    You will have to pull the low deep reduc. piston out of back of back box and clean or replace O/rings and ck for water in the pistons where it slides?
    Wncdb Thanks this.
  4. Wncdb
    4
    Mar 5, 2020
    North Carolina
    I didn’t realize their was all that in the deep reduction valve! Makes since tho, thanks for the info I will check into it tomorrow!
