Help : Gauge Lights Not Working
Discussion in 'Peterbilt Forum' started by Trygg, May 23, 2014.
  1. Trygg
    Trygg Light Load Member
    221
    187
    Feb 11, 2014
    The West
    I'm in a 2013 Peterbilt 587 and the back panel lights on the gauges aren't lighting up, can't see any of my gauges at night now. I checked the fuses that I have access to, and replaced nearly all of them but it didn't fix it. Does anybody know where the fuse is located for these lights? I'm assuming that's the problem, but it's not located in the side box on the passenger side where all my other fuses are. The dimmer switch is working for the computer on the dash, that displays your mpg and such, I'm using that right now to see my rpms. I don't understand why everything else just went out. I need help in fixing this asap, thanks.
  3. olphart
    olphart Medium Load Member
    301
    146
    Feb 15, 2009
    Minden,LA
    Mine does that too. Believe it or not the next time I turn the key off and back on they start working again.
    KillingTime and Judge Thank this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    No fuse for them, they're powered by the body control module. You need the Paccar ESA program to diagnose.
  5. Trygg
    221
    187
    Feb 11, 2014
    The West
    Really? Why couldn't they just make things simple for me. :(
    Like hart posted above, my lights lit back up after the truck was turned off for a few this morning while fueling up. I have no idea why they did that, maybe something shorting out?
    I had tried when I first woke up that morning, and found out that they weren't working, to turn the truck off and then started it again thinking maybe it was just a small glitch and it would fix itself, it didn't work at that time, but the difference later when I was fueling was that the truck was off for about 30 minutes while fueling before being restarted, so I guess it just needed more time of being off to reset. I don't know, I hate mechanical stuff.
  6. GrapeApe
    2,215
    2,212
    Jan 7, 2013
    We had a 2012 that did that once in a while, once we bought Paccar ESA (the program used to diagnose the multiplexed electronics), there were software updates, it never it it again. I'd give Pete a call with your VIN and ask if they there was a software release since you owned it. There's been a few updates over the years to fix glitches.
  7. peterleader
    peterleader Bobtail Member
    6
    4
    May 24, 2014
    I hd this problem before and the solution is actually simpler then you think, all you really need to do is get a flashlight.
  8. mc8541ss
    mc8541ss Road Train Member
    1,468
    2,017
    Sep 22, 2007
    Lower Alabama
    Why should you need a flashlight with a 2013. At last no further than it takes to get to the shop.
  9. PBKW
    PBKW Bobtail Member
    10
    Apr 6, 2014
    Canada
    Get your dealer to check ESA very recent update which fixes this issue.
  10. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    They'll do that when the key is left 'on' with the running lights on for an extended period of time. There is no fuse. Simply get in the truck with brakes set and doors shut turn the key to 'on' let it do its thing then turn it back off..... repeat severl times and it usually resets the system.
    AxiomAT Thanks this.
  11. AZ379PETE
    AZ379PETE Bobtail Member
    5
