HELP---HID Lights For 2004 and up Volvo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by scsapril69, Oct 10, 2010.
  1. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    So you're telling me that the LCM can tell if you have a headlight out WITHOUT ever turning on the headlights?
  3. josh.c
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    And no, I do not know anything about LCM or Version 2. Didn't know they existed.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    Yeah! just pull out any bulb and you'll get fault code, No fuse for every bulb, in case of short wires unit disables bulb till wiring is fixed.
    But there are hidden fuses (six under the unit) on red wires. This is battery power.
    LCM has MID 216,
    PSID 2 - Low beam left (not dr. side becouse LCM is one for all markets with 12V and 24V, including driving on left countries, like Australia, India, Africa and UK).
    MID216 PSID4 Low beam, right hand side
    MID216 PSID 13 Left front dir light
    MID216 PSID 14 right front dir light
    MID216 PSID 15 Left tail dir light
    MID216 PSID 16 right tail dir light
    MID216 PSID 17 Left trailer dir light
    MID216 PSID 18 right trailer dir light
    Types of faults:
    FMI 5 - low current, bad ore wrong bulb, broken wire
    FMI 6 - current over 5A ore power supply over 16V, usually this code appeares when wires are short to ground.
    josh.c Thanks this.
  5. josh.c
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    Wow-that's insane. So the only way to do it the way I was talking about without throwing codes would be to leave the factory bulbs dangling in their pigtails, and buy new pigtails for the HIDs. I don't guess it has a sensor that can tell if you put a piece of electrical tape over the fault light in the dash, does it?:biggrin_25523:
    Sorry for the thread hijack, and thanks for your input Pablo.
  6. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    some owners add fog lamps and connect them to low beam wires....
    but why not to visit a dealer to reprogram LCM? ore they wanna to many $$$$ for this?
  7. scsapril69
    scsapril69 Bobtail Member
    7
    Feb 4, 2010
    Eden NC
    I've checked with a Volvo dealer in Nebraska about reprogramming my
    computer to accept HID lights and their cost is $500. 00. This is crazy, I will check around for better pricing. I refuse to pay this much just to change a lighting program.
  8. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    I do it for $100.... but I'm too far....
  9. jolige
    jolige Bobtail Member
    11
    Oct 23, 2010
    canada
    Dear Pablo:
    It sounds to me that you are a really nice guy who knows what he is talking about and I think you would know there is a possibility to bypass LCM without getting fault codes. What I mean that you already tried to outsmart the "smart" sweden system. помоги пожалуйста.
  10. Pablo-UA
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    yeah, there is a way! install two additional fog lamps in bumper with 55 Wt bulbs and connect them to Low beam wires in headlamp. allso add two relays and use them to light the HID! That is all
    As I remember in EU headlamp 24v H7 are used, in US headlamos they use 12V H11..... Both 55wt
  11. Magnum1
    Magnum1 Medium Load Member
    567
    28
    Dec 13, 2010
    NJ
    Ok, here it goes. To all who say that hid is bad and you can not see at night. To all who say that you'll get the CEL/similar with the hid. Plus, others. = you're wrong. 98% . I sell hid kits. I install hid kits. I also
    Advice not to buy anything under $150 and above $300. Under $150 the quality is not there, over $300 is overpriced. Talking from personal experience here ; have two of my own cars, in which hid is installed as the low beam. One of my car's uses the same bulb for the
    High and low beams bi's. - this car has the wiring harness and the kits are more expensive for this type of the set up. My Honda motorcycle has hid kit. My brothers acura has original crappy hid kit, which is going out soon. My fog lights have the hid kit. Now, my rig has the hid kit. Installed them all my self. Sell them too. Now, the brightness of the hid bulb will Be dependent on the kalvin temp of the light , not to be mistaken with the C or F temperature. Hid can be installed into any headlight that has the removable bulb. I have the 2007 Volvo vnl780 with the hid kit and had no need to go to the dealer to pay them for the reprograming truck's computer. That's another reason why the price was quated at the higher number. Kit carries 3 year warranty. Hid's work fine in the Projected or halogen headlights.
